Extract oil thru dip stick tube - Honda Pilot - Honda Pilot Forums
Old 08-18-2004, 11:09 PM   #1 (permalink)
Default Extract oil thru dip stick tube
Is anyone else using an oil siphon pump to remove old oil through the dipstick tube? It's much easier - no need to get under car and remove plug - appears to remove all of it - have used this recommended method on BMW's and Benzes for years.
barbershoptenor is offline   Reply With Quote
Old 08-19-2004, 04:46 PM   #2 (permalink)
Just Me
kettlinton's Avatar
Send a message via Yahoo to kettlinton
what if there is something at the bottom of the oil pan. draining the oil seems better to me. that is my opinion
Honda Fan From Day 1!
03 Honda Pilot White EX-L
Mud Guards, Window Vents, Door Handle Accents, Grill Accents, Bumper Accents, Exhaust Tips, Window Tint, Rockford Fosgate Amplifier, 2-12inch Subs, 10inch sub(stock location),
Sony In-Dash Radio, Cargo liner,
Class III U-Haul Hitch
kettlinton is offline   Reply With Quote
Old 09-13-2004, 08:56 AM   #3 (permalink)
That's like buying a new pair of shoes and tieing the string in a knot and making them slip on's
Old 09-13-2004, 02:35 PM   #4 (permalink)
What do do do about the oil filter? If you don't change it every time you are leaving dirty oil in the engine and if you do change the oil filter I don't find it much more trouble to pull the drain plug.
pjb3 is offline   Reply With Quote
