DIY Cabin Filter Replacement - Page 8 - Honda Pilot - Honda Pilot Forums
LinkBack Thread Tools Rating: Thread Rating: 7 votes, 5.00 average.
Old 03-07-2006, 11:55 PM   #106 (permalink)
onu2002's Avatar
Originally posted by kingkaoppa
where can I buy the hepa filter in Los Angeles area?
Autozone & Pepboys did not have it...
NAPA can order it for you.
Tom
2003 Honda Pilot EX
2004 Honda S2000
2006 Hyundai Sonata GLS
Old 03-08-2006, 01:16 AM   #107 (permalink)
knight rider suv
CAVBOYGT's Avatar
can u just use a sponge or filter for home heater to replace the hepa filter? whats the diff? and do u really need to cut that plastic DIY ?
Bumper Garnish, Door Mirror Covers, Rear Splash Guards, Chrome Side Steps, Exhaust Finisher (4WD Models Only), Cargo Cover, FleaMarket Custom Seat Cover 1st 2nd & 3rd row, USA SPEC ipod interface, Full Mask, all weather matand cargo, dvd headrest, exotic dash wood.
CAVBOYGT is offline   Reply With Quote
Old 03-08-2006, 01:42 AM   #108 (permalink)
If you don't cut the plastic you won't be able to remove the filter. I guess you could use another filtering medium, but you would not have as much air passing through if you did causing an inefficient system and thus making it work harder to pull air through. Honda engineers made the filters like that for a reason.
Old 03-08-2006, 10:41 AM   #109 (permalink)
Default Hepa filter?
What????? There's a Hepa filter available as a replacement cabin filter? Or is kingkaoppa refering to the standard cabin filter avilable from most auto parts stores and the dealer?
Thanks!
Larry.
DiskStroyer: http://www.diskstroyer.com
larrys is offline   Reply With Quote
Old 03-08-2006, 01:25 PM   #110 (permalink)
I think he means the regular filter. I really doubt any of the major chains would carry a hepa cabin filter.
Old 03-08-2006, 01:41 PM   #111 (permalink)
Tim
(the other one)
Tim's Avatar
I believe the Honda filter is a "micron filter". But then so is a "Hepa filter".......
The Fleet;
04 EX-L Pilot, Sage Brush Pearl: Chrome Steps, Crossbars, OSRAM "Night Breaker" bulbs, Auto Day/Night Compass Mirror, Cargo Tray, Rear Splash Guards, LED Marker/Signal Light Bulbs and interior bulbs, SS Tips, WWong's pads and a Garmin c530.
01 Nissan Maxima SE, In Leather, 5-Speed, (the fun car), Silver: PIAA Super Extreme White Headlight Bulbs, LED Marker/Signal Light Bulbs
The Loonie Twins;
(Two) 04 Toyota Corolla LE's , 1) Moonshadow Metallic, 2) Lunar Mist Metallic, side bags, anti-lock brakes and (of coarse) LED interior/exterior bulbs
www.albinoblacksheep.com/flash/posting.php
Tim is offline   Reply With Quote
Old 03-10-2006, 05:17 PM   #112 (permalink)
kingkaoppa's Avatar
it was micron filter... my mistake... sorry...
went to the dealer and they asked for $50.00
(also asked VTM fluid change price... they said $50~$60)
so i went to the autozone and ordered one at $32 something... (BOSCH)
will pick it up tomorrow...
thanks for your info fellow members...
kingkaoppa is offline   Reply With Quote
Old 04-10-2006, 01:29 PM   #113 (permalink)
Tim
(the other one)
Tim's Avatar
just replaced mine for the first time at 20K miles. took a little over an hour thanks to the great instructions. filter was filthy........
The Fleet;
The Loonie Twins;
Old 04-11-2006, 01:21 PM   #114 (permalink)
Since I had to remove the glove box to install the PIE X3 adapter last Sunday, I replaced the cabin filter at the same time. It took me about half an hour with the excellent instructions from this site and a rotary cutting tool. I got the Bosch filter from Murray's for $19.99. The original filter was really dirty. I plan to replace it every year.
MiPilot
Starlight Silver EX-L, Air Deflector, Running Boards, CD Changer, Cargo Cover, Cargo Tray, Rear Splash Guards, WeatherTech All Season Floor Mats & Window Deflectors, Sylvania SilverStar, PIE X3.
MiPilot is offline   Reply With Quote
Old 04-28-2006, 07:39 AM   #115 (permalink)
Just what I needed! Thanks! I was afraid I'd have to remove the whole dash...
~ Lay & Vina ~
- 2003 Nighthawk Black Pearl, EX-L 4WD
- 1991 Honda CRX Si
- 1978 Honda CVCC wagon - 1.6L DOHC ZC swap
Layspeed is offline   Reply With Quote
Old 05-29-2006, 08:17 AM   #116 (permalink)
sillec's Avatar
Default Double Amen
Originally posted by john802
I wish honda engineers design it like the '03 accord. You spend 5 minutes tops changing the cabin filter on that one(tool-less DIY).
Double Amen.
Thank you Hondaman2 and all other contributers to this thread. Don't think I would have tackled this one on my own without the excellent instructions. In reality, not too bad except for that right side glove box screw which was a nuisance but certainly doable.
'03 Pilot EX Redrock - June 2002
Foglights w/o trim; Full-size spare; Cargo tray; Cargo cover; All-weather mats; Rear splash guards
sillec is offline   Reply With Quote
Old 05-29-2006, 12:11 PM   #117 (permalink)
Drill Here, Drill Now
jdeanski's Avatar
Just replace mine today at 29000 miles. Hardest parts were removing the glovebox with the stops in place and cutting the plastic brace out. I was going to use my Rotozip but uses a wire cutter instead. When I reinstalled the glovebox I removed one of the stops.
I also was going to clean my K&N air filter but it wasn't dirty. It looked like the day I installed it unlike the cabin filter which was pretty dirty.
1984 Jeep CJ7
2004 Pontiac Vibe
Old 07-03-2006, 12:29 PM   #118 (permalink)
First, thanks for the awesome instructions, Hondaman2. Took me an hour and saved me about $100 (next time, now that I am "experienced" should be less than half that). Filter was filthy. Second, what an odd way to place a filter that needs to be replaced every year. I couldn't believe I had to cut the dash frame to get at the filter and figured there must be another way, but nope. Weird but I guess it keeps the faint of heart without good instructions like these from trying it. Fred
fhoran is offline   Reply With Quote
Old 07-03-2006, 12:36 PM   #119 (permalink)
jay
jay's Avatar
I think it's just a function of how the dash had to be manufactured for installation into the vehicle. But what a pain that first time!
Old 07-03-2006, 05:49 PM   #120 (permalink)
I think you are probably right jay but I am also guessing that Honda doesn't feel terribly motivated to make filters like this easy to replace since they can get $125 (my local dealer's charge) to replace it once a year.
