Crush washer and Plug pics - Honda Pilot - Honda Pilot Forums
Old 08-02-2004, 03:46 PM   #1 (permalink)
Superior Honda Tech
hondaman2's Avatar
Default Crush washer and Plug pics
I took some samples, take a look
Old 08-02-2004, 03:48 PM   #2 (permalink)
Superior Honda Tech
hondaman2's Avatar
another look
Old 08-02-2004, 03:49 PM   #3 (permalink)
Superior Honda Tech
hondaman2's Avatar
some mediocre washers
Old 08-02-2004, 03:49 PM   #4 (permalink)
Superior Honda Tech
hondaman2's Avatar
good washers, rubber insulated is the best.
Old 08-02-2004, 03:50 PM   #5 (permalink)
Superior Honda Tech
hondaman2's Avatar
not re-usable
Old 08-02-2004, 03:51 PM   #6 (permalink)
Superior Honda Tech
hondaman2's Avatar
over size, for fixing stripped threads on the pan.
Old 08-02-2004, 03:52 PM   #7 (permalink)
Superior Honda Tech
hondaman2's Avatar
bad plugs
Old 08-02-2004, 03:55 PM   #8 (permalink)
David Ming's Avatar
Thank You HondaMan2 for all of the great pictures and info. Keep it coming!!!
2003 Starlight Silver Pilot EX-L RES
OEM: Rear Mud Flaps, Air Deflector, Cross Bars, Honda Short Roof Box,
All Weather Floor Mats, Cargo Cover, Roof Mount Bike Racks (2), Tow Hitch with Power Steering and ATF Coolers, 2004 Horn Upgrade, MDX Rear Subframe Retrofit Kit, Airlift 1000
Goodyear Forterra TripleTreads
Stainless Steel Exhaust Tips Model: Pilot Motorsports PM-554
2001 Satin Silver Accord EX Bone Stock Plus: OEM All Weather Floor Mats
David Ming is offline   Reply With Quote
Old 08-02-2004, 07:27 PM   #9 (permalink)
DanL's Avatar
I hope to God I never have to use one, but where do you get oversized drain plugs? Is that something available from the dealer?
'04 Sandstone Metallic EX-L RES, Side Steps, OEM Wood Trim, Mud Guards, Cargo Cover, Cargo Tray, Yakima Lowriders + fairing, Alpine S620 CD Changer, Kenwood 1679IE Front & Panasonic DD163 Rear Speakers, wwong's Rubber Insert Thingies, Ratso's Shiny Chrome Grill Thingies.
DanL is offline   Reply With Quote
Old 08-02-2004, 07:51 PM   #10 (permalink)
Superior Honda Tech
hondaman2's Avatar
oh ya, the best way to tell if the crush washer is re-usable is to see if it is wider than the plug. If you look closely to the pics, you can see the bad washer is overlapping the plug and the good washer is not.
you can get oversized plugs from Napa or auto parts stores like Car Quest. I recommend taking the plastic crush washer off and replacing it with a factory one or a rubber insulated one. Plastic washers suck and when they get hot they gat hard and then crack and then the plug leaks.
Old 08-02-2004, 11:33 PM   #11 (permalink)
Superior Honda Tech
hondaman2's Avatar
good crush notice the washer is not over lapping the plug
bad crush the washer is over the lip
going from the thickness of a nickle to the thickness of a dime.
and the width/diameter of a quater to the width/diameter of a half dollar.
Old 08-03-2004, 03:45 AM   #12 (permalink)
CarolinaPilot's Avatar
I have had cars that do not use a crush washer. Why do we need crush washers with engines and others that do not need them? Thanks.
06 Steel Blue Ridgeline RTL S/R with tow and fogs.
A former 03 Standstone LX-RES w/towing package, x-bars, rear mud flaps, Husky floor liners, cargo mat, Delphi SkyFi XM Radio and Michelin Cross Terrains with full size spare that served me well for over 51K miles.
I steer a hydrostatic Honda Harmony HRB215HXA, roto-till with a Honda FG110 and peddle a Honda Trail Pilot bicycle.
CarolinaPilot is offline   Reply With Quote
Old 08-03-2004, 10:50 AM   #13 (permalink)
Superior Honda Tech
hondaman2's Avatar
you need crush washers with metal oil pan. The pot metal pan is one you dont but I still put em on as extra incentive. Especially since they have the high school drop out jacka$$ pump jockey doing oil changes at the 10 minute quick lube and if he screws anything up using American wrenches or air tools he just smothers silicone all over it (see stripped threads) and calls it done.
You need on on the metal for sure because if you over torque it to much it will pull the threads out toward the plug there by making the surface uneven. Sometimes we have to weld a nut on the pan to make new threads or if its real bad we install a new pan.
The aluminum pan has a metal sleeve with threads in it just like your engine block and head. These are almost impossible to fix without replacing the pan.
And considering the fact that the washer is less than a dollar its worth it, especially since the alternative is much more pricey.
Old 08-03-2004, 04:17 PM   #14 (permalink)
DanL's Avatar
WAY less than a dollar. I purchased a dozen the other day for $3 at my local dealer. That's a $1 a year (assuming my standard 4 oil changes a year). Think I can afford that.
Old 08-03-2004, 10:26 PM   #15 (permalink)
jazcar's Avatar
Hondaman2,
Last time I changed my oil (Acura 2.5TL), I couldn't remove the crush washer from the plug (it was overtorqued). I re-used it and it didn't leak. Maybe I didn't use the right tools, but is it better to try like crazy to separate the washer from the plug if the washer is smooth with no raised areas? or is it better to buy a new plug and crush washer?
By the way, not only was the crush washer overtorqued, I couldn't remove the filter with the correct filter wrench (end cap style is the only way to get the filter off). I had to leave that filter on and get someone else with better tools to change my oil on an abbreviated schedule to get back to normal.
It's hard to get a good mechanic these days. Shouldn't be that way for a simple oil and filter change.
JAZ
2003 White EX #600465
Fog Lights, Rear Splash Guards, Towing Package, Cross-bars, X-Pel Headlight and Foglight Protection, 3M Invinca-shield, All Weather Mats, Thule 939 Switchback Bike Rack, Thule Evolution 1600
jazcar is offline   Reply With Quote
