The book says 29lbs, When I changed the oil I noticed a little residue by the drain plug. I changed the oil and intalled a new crush washer, torqued to 29lbs. Not a lot of clearance under there for a torque wrench. Yesterday I noticed oil leaking from the plug. This morning I bought some rhino ramps ( Perfect clearance ) and torqued it again this time tighter around 34. Anyone else had this problem? The wife is driving it now I'll re check it when she gets back
2004 EX SageBrush Pearl Bought her Jan Wheel Locks | Cross Bars | OEM Side Steps | Rear Splash Guard | Cargo Tray and Xanimo-net sticker |
Rip Tide Dude!
Are you sure your torque wrench is accurate? I always have my torque wrench recalibrated every year at my work place, and they usually off by +/- 5 lbs-ft after a couple of usage.
-john
Although everything has a torque spec, it doesn't mean it's that critical. I've never used a torque wrench, or ever seen one used, to tighten a drain plug. I've never had one leak, even using the same washer over and over. The torque spec I usually use is "sock it down good and tight", without getting ridiculous, assuming I'll be the one who will have to remove it in a few months for the next oil change.
The current spec is "Just sock it down tight enough". Seems aluminum parts did not like the "Good and Tight" spec.
I agree. Just be sure not to crank it down like some ape!!!
'03 Starlight Silver EX-L...Rear Splash Guards, Cargo Tray, All-Season Mats (Husky Liners In Front), Trailer Hitch, 3M Clear Nose Mask, K&N Performance Air and Oil Filters, Mobil1 5W-20 Oil, Sylvania Silver Star Bulbs, FS Spare, Michelin X Terrains, Bosch Micro Edge Excel Wiper Blades, Amsoil ATF, Bosch Premium Oil Filters, Purolator PureONE Oil Filters, Fumoto Oil Drain Valve, Akebono Ceramic Pads, Brembo Rotors- |
I always have 500 ml bottles of water on hand. Here's a use for the empty's.
No need to clean a funnel, just toss with the empty oil containers. You'll want to wipe it dry before, of course.
2004 SS EX |
![]() ![]() ![]() Join Date: Aug 2003
Glen ps - for those who didn't get it, that was a joke. Don't use a cheater bar to tighten an oil drain plug! |
