Wiper blade replacements - Honda Pilot - Honda Pilot Forums
Old 06-17-2004, 02:11 PM   #1 (permalink)
That whole brevity thing.
elduderino's Avatar
Default Wiper blade replacements
I was curious as to what everyone's opinion is towards replacing the wiper blades. 1) install new OEM wiper inserts. 2) replace the wiper blades with cheap aftermarket blades (ie. the yellow brand at Advanced Auto Parts.) 3) replace with premium wiper blades (ie. Bosch microblades.)
With how wiper blades take so much abuse, option 2 might be the easiest and most cost effective. Or option 1, depending on how much work is involved with replacing only the inserts. Or mayby option 3 because a good blade will last longer than the other two options.
Also, I've read where the rear blade is a lot harder to replace than the front ones. Is this true and if yes, what are some of the tricks to make the job easier.
2004 Pilot EX Starlight Silver Metallic
OEM All-Season Floor Mats
OEM Cargo Tray
OEM Side Steps
OEM Cross Bars
WeatherTech Stone and Bug Deflector
Wheel Locks
Splash Guards
Pinstripe Detailing
elduderino is offline   Reply With Quote
Old 06-17-2004, 02:46 PM   #2 (permalink)
Stevie B's Avatar
I haven't had to replace the Pilot wiper blades just yet, but with all of my other Hondas, I got in the habit of doing it twice a year, fall and spring. When I lived in Oregon I sometimes replaced them three times a year. Anyway, I've always had good luck with the Honda blades and the prices (for the Accords) seem to be around $15 for two. That's my .02.
'04 Pilot, NBP, EX-L RES
'89 Toyota Land Cruiser
Stevie B is offline   Reply With Quote
Old 06-17-2004, 03:11 PM   #3 (permalink)
rockman19762001's Avatar
I replace my blades twice a year, in West Texas the heat and sun deteriorate the blades regardless of the price. I usually buy a medium price rubber blade insert or replacement what ever they have in stock.
Old 06-17-2004, 07:00 PM   #4 (permalink)
I replace the entire blade when needed, (about once a year). My cars are garaged so this may help prolong the blade life. I also replace them with a premium blade. It's a lot simpler than screwing around with the rubber insert for only a couple of bucks more.
Old 06-17-2004, 08:19 PM   #5 (permalink)
Birdman's Avatar
The original Honda blades seem to work well if you don't mind messing with installing the inserts. I put cheap Anco blades on my Pilot and they slap when reversing direction, so I don't recommend those.
Birdman is offline   Reply With Quote
Old 06-17-2004, 09:49 PM   #6 (permalink)
Le Moderator™ Ranger®
kemosabe's Avatar
Two years later and I'm still on the original wiper blades and inserts -- they still clean/clear the windshield perfectly, so until I see some deteriorating sweeps across the glass, I plan on keeping/using them...
Old 06-17-2004, 10:23 PM   #7 (permalink)
jay
jay's Avatar
The benefit of a garage-kept vehicle. I replace the inserts every year near the anniversary of buying the vehicle.
Of course, I once had a stinkin' outdoor-kept GM vehicle where the blades didn't last a year. They fell apart, leaving a sticky rubber mess on the windshield during a downpour while I was on vacation, miles from nowhere, headed toward the Outer Banks.
Old 06-17-2004, 10:58 PM   #8 (permalink)
Drill Here, Drill Now
jdeanski's Avatar
Bosch Microblades are the best I've ever owned. But I haven't tried the PIAA silicone ones.
1984 Jeep CJ7
2004 Pontiac Vibe
Old 06-18-2004, 09:09 AM   #9 (permalink)
Sunday Rider's Avatar
Hi elduderino,
the honda blades are very easy to replace. The rear one is not hard at all. You just have to clear the extra lip on the rear wiper arm. As long as the arm is okay I will replace the blade only. It is a shame to just throw out plastic arms, when all you need is a new blade. And did I mention cheaper. Just think for evey time you replace the balde only, you can take the difference and buy a WWong goodie for the inside...
Sunday Rider
Honda ST1100 '97
Honda CB900C '82 sold
Honda CM400E '80
Old 06-18-2004, 09:55 AM   #10 (permalink)
calpos's Avatar
Another suggestion.... every time you wash your car, take a terry or other slightly abrasive rag and "wash" the wiper blades by holding onto one end and pulling down its length. Be careful that you don't rip it or spring the blade holder or arm. And don't do this with a mitt or anything you want to keep clean, because you'll wash off a lot of the oxidized rubber from the blade but they'll work a lot better.
I don't think you could ever "wear out" the blade by washing it too much, but if you get enough oxidation built up on it, it losses its squeegee effect, becomes hard and won't work very well.
Brian
calpos is offline   Reply With Quote
Old 06-18-2004, 12:14 PM   #11 (permalink)
jazcar's Avatar
I have been very happy with Bosch Microblades.
JAZ
2003 White EX #600465
Fog Lights, Rear Splash Guards, Towing Package, Cross-bars, X-Pel Headlight and Foglight Protection, 3M Invinca-shield, All Weather Mats, Thule 939 Switchback Bike Rack, Thule Evolution 1600
jazcar is offline   Reply With Quote
Old 06-18-2004, 12:29 PM   #12 (permalink)
MG Pilot's Avatar
See my sig...
'03 Starlight Silver EX-L...Rear Splash Guards, Cargo Tray, All-Season Mats (Husky Liners In Front), Trailer Hitch, 3M Clear Nose Mask, K&N Performance Air and Oil Filters, Mobil1 5W-20 Oil, Sylvania Silver Star Bulbs, FS Spare, Michelin X Terrains, Bosch Micro Edge Excel Wiper Blades, Amsoil ATF, Bosch Premium Oil Filters, Purolator PureONE Oil Filters, Fumoto Oil Drain Valve, Akebono Ceramic Pads, Brembo Rotors-
MG Pilot is offline   Reply With Quote
Old 06-18-2004, 02:15 PM   #13 (permalink)
Sandcrab's Avatar
I know you all know that the driver side is 24" and passenger side is 21". When I replace the driver side, I always go with 2" longer (26") to clear more windshield.
04 EX Midnight Blue Pearl, XM Commander radio, Mudguards, Wheel locks, Weathertech front window visors, Lund Air Deflector, Front window tint, Cobra 75 WX ST Mobile CB
Sandcrab is offline   Reply With Quote
Old 06-19-2004, 10:38 PM   #14 (permalink)
elduderino's Avatar
Really? Any problems with clearance with the passenger side wiper?
OEM Cargo Tray
OEM Side Steps
OEM Cross Bars
Wheel Locks
Splash Guards
Pinstripe Detailing
Old 06-20-2004, 02:05 PM   #15 (permalink)
If you go with an aftermarket buy something upper end with a metal arms not plastic.
