Advise on replacing drive belts! - Honda Pilot - Honda Pilot Forums
Old 02-20-2004, 01:48 PM   #1 (permalink)
Default Advise on replacing drive belts!
What advise should an novice car owner know about replacing the Pilot drive belt? Any suggestions, ideas and proper procedures would be appreciated.:
yesdin is offline   Reply With Quote
Old 02-22-2004, 02:32 PM   #2 (permalink)
Are you Army Strong?
Jiaronnis's Avatar
Let the experts do it
Jiaronnis is offline   Reply With Quote
Old 02-22-2004, 06:38 PM   #3 (permalink)
Olde Timer Administrator
colorider's Avatar
Default Re: Advise on replacing drive belts!
Dirve belt? Help me out here...... what drive belt??
Oh yes - welcome to the forum!!!
Where are you at in Colorado?
'10 Honda Pilot EX-L
'11 Ford Mustang GT/CS
'12 Yamaha XT1200Z
Enjoy Life Today
Yesterday Is Gone
Tomorrow May Never Come
Old 02-22-2004, 06:56 PM   #4 (permalink)
Default Live in SW Denver area
I live in the SW Denver metro area. I thought that this Pilot is a typical Honda and has a timing belt that needs to be replaced at 60K. Am I right?
Old 02-22-2004, 07:04 PM   #5 (permalink)
jay
jay's Avatar
Default Re: Live in SW Denver area
105k, not 60. Thanks to kemosabe and bkwon for scanning/posting and hosting the '03 Owners Manual. It's a good read. I highly recommend it.
Old 02-22-2004, 07:18 PM   #6 (permalink)
colorider's Avatar
The 60,000 mi/96,000 km/4 yrs Scheduled Maintenance
Replace engine oil & Filter.
Rotate tires.
Replace engine oil filter.
Check parking brake adjustment.
Inspect brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids, and check for leaks.
Inspect exhaust system.
Inspect fuel lines and connections.
Inspect cooling system hoses and connections.
Inspect front and rear brakes.
Inspect tie-rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
Inspect and adjust drive belts.
Replace dust and pollen filter.
Replace air cleaner element.
Replace rear differential fluid.
No mention of replacing the timing belt until 105K
'12 Yamaha XT1200Z
Enjoy Life Today
Yesterday Is Gone
Old 02-23-2004, 10:36 AM   #7 (permalink)
Is the Pilot's engine an "interference" type where a timing belt failure (and resultant loss of synchronization) causes the pistons and valves to make contact?
seadog is offline   Reply With Quote
Old 02-23-2004, 08:26 PM   #8 (permalink)
Birdman's Avatar
Yes, the Honda 3.5 L engine is the interference type. If you are even remotely considering replacing the timing belt yourself, invest some the money you save and buy (and read) the service manual before you start.
Birdman is offline   Reply With Quote
Old 02-23-2004, 10:21 PM   #9 (permalink)
ncelk's Avatar
I thought the timing belt did not have to be done until 105k.
Is anyone even near that? I probably would not do the accessory drive belt until that time either.
ncelk
2009 Toyota Camry Hybrid
2002 Mazda Miata SE
2006 Acura MDX Touring
ncelk is offline   Reply With Quote
