How to replace driver side mirror glass? - Honda Pilot - Honda Pilot Forums
Old 01-28-2004, 10:39 PM   #1 (permalink)
vjp
vjp's Avatar
Default How to replace driver side mirror glass?
Folks:
while backing out of my garage the other day, the driver-side mirror assembly touched the side of the garage door frame. Luckily, I was moving slow and stopped. The assembly had hinged back but was intact however the mirror glass had broken from the actuator assembly. The mirror did not crack.
I read somewhere that the mirror glass connects to the actuator with a ball and socket like joint, is this correct? It looks like to me that the "ball" broke off from the mirror glass and is still in the actuator "socket".
How can I remove the broken "ball" from the socket without causing further damage? I plan to replace the mirror but one side of me says maybe I can glue the ball back on to the mirror, probably should not do that, any suggestions?
If I get the replacement mirror, how do I install it correctly or do I have to take it to a mechanic?
Any suggestion will be greatly appreciated. Thanks
vjp is offline   Reply With Quote
Old 01-28-2004, 11:27 PM   #2 (permalink)
jtvicknair's Avatar
I hate to be the bearer of bad new..... but the sounds like the same thing that happen to my Ford explorer's mirror a few years ago----
the piece that holds the mirror in place and makes it move from side to side.....................
I had to replace the whole mirror because Ford didn't sell the replace part for the inside of the mirror. I guess I could have gone to a junk yard and found the part I needed from a wrecked one.
I paid the dealer... over 250.00 for the whole side mirror when the part I needed probably only cost 1.00
JT
2012 Dark Cherry Red EX-L with Navi
Cargo tray,
Cargo organizer,
All weather mats
jtvicknair is offline   Reply With Quote
Old 01-28-2004, 11:33 PM   #3 (permalink)
jay
jay's Avatar
Default Re: How to replace driver side mirror glass?
Originally posted by vjp
Folks:
Check out this web site. You may be able to order just what you need pretty inexpensively, based on the diagram and pricing at the web site.
Old 01-28-2004, 11:41 PM   #4 (permalink)
2003 SS EX-L RES
SteveLuman's Avatar
Send a message via AIM to SteveLuman Send a message via Yahoo to SteveLuman
Here is how the mirror holder connects to the actuator.
SteveLuman is offline   Reply With Quote
Old 01-28-2004, 11:42 PM   #5 (permalink)
2003 SS EX-L RES
SteveLuman's Avatar
Here are the instructions for replacing the power mirror.
Old 01-28-2004, 11:43 PM   #6 (permalink)
2003 SS EX-L RES
SteveLuman's Avatar
...and last, but not least, the Mirror Holder replacement instructions. This diagram may help you the most. If you need the actuator replacement instructions, let me know.
Old 01-29-2004, 08:41 AM   #7 (permalink)
Default HEATED SIDE MIRRORS
Does anyone know if the side mirrors on a 2003 Pilot (U.S. Model) can be replaced with a heated side mirror like in the Canadian Model (and I have noticed that this is an option on th '04 EX-L U.S. model)? If so, where can one order from, how much does it cost, and how difficult is this job?
2003 Pilot EX - Nighthawk Black
Honda Fogs/Garnish - Lower Trim Bumper (Front/Rear) & Side Mirror
Bridgestone Dueler H/L 245/70/16
Running Boards/Sylvania Silverstar/Rear Splash Guard/Wheel Locks/ Yakima Cross Bar w/Low Riders/Honda Hood Air Deflector /Michelin Wipers
Cargo Cover/WeatherTech Advantage Plush Mats
Ventshade Window Visors (wish I got
the Visors from WeatherTech
Hidden Hitch/Mobile One 0W-20
Pilot Owner is offline   Reply With Quote
Old 01-29-2004, 09:40 AM   #8 (permalink)
vjp
vjp's Avatar
Folks:
Thanks for your responses.
Steve, from your instructions I think I just need to replace the mirror holder since the tabs that hold it onto the actuator plate seem to have broken off. ~$15 solution that I can do myself thanks!
vjp, NJ
2004 Pilot LX
2000 Accord
Old 01-31-2004, 06:33 PM   #9 (permalink)
vjp
vjp's Avatar
Well I went to the dealer for a repair estimate on my broken mirror actuator plate.
The service guy I talked to said the whole housing had to be replaced! when I said "can't you just replace the actuator" since the housing is intact and so is the mirror glass and holder, he said "they don't sell it separately"! I knew that was not true because of help in this forum. When I talked to the parts guy he said he could order the actuator separately but for $58 (this is for a 2004 LX). Again I new for this forum that one can order these for around $36 over the internet. Then I went back to the service guy for a labour estimate, he said that would be $114 to replace the actuator. All these prices seem quite high to me. I realize I can order the part over the internet but are there any things I need to keep in mind when doing this? Then comes the replacement, I will probably attempt that myself, it does not seem that involved from the instructions Steve sent, but again I am novice (to say the least) at this sort of thing. Any suggestions?
vjp, NJ
2004 Pilot LX
2000 Accord
Old 02-19-2004, 06:07 PM   #10 (permalink)
Send a message via Yahoo to PatrickC1026
Local dealers charge you more most of the time. However, one of the local Honda dealers in my area matches the internet price if I show them the print out. You might want to try too.
For installatiion, $114 is too much. I think it should take only one hour, two hours the most. Of course dealer's labor rate is very high. However, nothing can replace the satisfaction after you do it on your own.
'03 Pilot EX-L w/ RES, Starlight Silver
Running boards | Roof cross bars | Roof basket | Full nosemask | Chrome side mirror covers | Dashboard cover | Wood trim interior | Cargo tray | Separation net | Rear splash guards | Wheel locks | Chrome exhaust tips | Full size EX spare
'11 Toyota Camry 4 cyl, XLE, Silver
'92 Prelude Si, Milano Red (>225,000 miles)
PatrickC1026 is offline   Reply With Quote
Old 02-25-2004, 10:03 PM   #11 (permalink)
vjp
vjp's Avatar
Talking Thanks everyone!
Folks:
I did it. I replace the broken mirror actuator (actually only the actuator plate was broken). Getting the actuator from Arizona took some time (I live in NJ and opted for ground shipping). There was also some confusion with the color coding on the wires, the part I received had color coding for the passanger side, while I ordered the driver side actuator. I got it to work. The toughest part was getting the mirror holder onto the actuator plate. I did not want to apply too much pressure since the plate broke in the first place.
Anyhow it is repaired now. I am happy I did it myself. Thanks to everyone for the help with the manual pages and advice.
vjp, NJ
2004 Pilot LX
2000 Accord
Old 02-25-2004, 11:23 PM   #12 (permalink)
2003 SS EX-L RES
SteveLuman's Avatar
Congrats,
What did it end up costing you to repair the mirror?
Old 03-01-2004, 11:18 PM   #13 (permalink)
vjp
vjp's Avatar
Steve:
Thanks for your help.
I spent ~$36 on the actuator and had to buy a star screwdriver key-set for ~$10. Getting the mirror holder on the actuator plate was the hardest part for me because I was worried it might break again at the joint.
vjp
vjp, NJ
2004 Pilot LX
2000 Accord
Old 03-02-2004, 09:22 AM   #14 (permalink)
2003 SS EX-L RES
SteveLuman's Avatar
Steve:
vjp
Congrats...I think that $ 46.00 is much beter than the $ 172.00 your dealer wanted.
Old 03-03-2004, 03:35 PM   #15 (permalink)
vjp
vjp's Avatar
Talking
Yes:
It is much better.
And also a confidence builder.
vjp, NJ
2004 Pilot LX
2000 Accord
