Ferdspeed3
I have my check engine light on, and my handy little Car Chip says that its a Trouble Code P2086. It gives a brief description and some various engine data:
Description: Unknown Powertrain DTC (SAE Controlled; Fuel and Air Metering and Auxiliary Emission Controls) Engine Status: Intake Manifold Pressure (Absolute): 4.9psi Engine Coolant Temperature: 183.2 degrees F Calculated Load Value: 33.7% Engine Speed: 3 RPM Vehicle Speed: 0 MPH Fuel Trim Status Short-Term Fuel Trim (Bank 1): -11.72% Long-Term Fuel Trim (Bank 1): -2.34% Fuel System Status Fuel System 1 Status: Closed loop; using oxygen sensor(s) as feedback for fuel control. Can anyone with a shop manual or mechanic status give me any more insight to this code? I'm going to take it in next week, but I want to know what to expect. BTW, I called to get the recall work done at my local Honda dealer, and they said its a two week wait. Nope.
03 Pilot EX-L Starlight Silver #18440 P0470 = $3700 |
Where would someone with a Service Manual look. There's nothing in the index about OBD codes, troubleshooting codes, etc.
![]() ![]() ![]() ![]() ![]() Join Date: May 2003
My guess would be Mass airflow sensor or o2 sensor! But that is only based on similar wording in VW trouble codes not any Honda knowledge!
Matt
2003 Pilot EX-L RES (rcvd 5/3/03) 2003 VW Jetta GLi 2003 Honda VFR800i 2003.5 Coleman Cheyenne |
Le Moderator™ Ranger®
Ferdball: I've looked in the following DTC Troubleshooting Indexes from the Service Manual:
__________________ |
Admin Du Jour ®
My guess:
P2086 Exhaust Gas Temperature Sensor Circuit Range/Performance (Bank 2 Sensor 2) from here: http://www.actron.com/obdii_code.pdf (via Google) The service manual doesn't list such a code anywhere.
Ferdspeed3
The wife went with a friend for a day of shopping (she doesn't have a job!!!). They came right back after noticing a strange noise. It's definitely going in tomorrow. Papa's MDX makes a good standby vehicle.
The description from the Car Chip and the link from TheWorm point to an emissions issues. Maybe this will solve my 15.6 MPH gas mileage situation. Story at 11. Stay tuned.
Ferdspeed3
The light on the dash and the code posted earlier was from someone leaving the gas cap off. Since I don't drive the Pilot much any more, I'll leave it up to you to figure it out (it was the WIFE!). So, no help with the mileage issue.
About the vibration, they said that there were bald spots on the tires and that maybe I made some hard stops. Apparently, I know how to circumvent the Anti-lock braking system and went willy-nilly with some power slides. And that these 'flat spots' seem to resonate at such a rate that I only feel them above 70 MPH. Hmmm... seems reasonable, if you're a Service Advisor! Anyway, I got the recall work done ahead of schedule. The cap was replaced for free.
#9 (permalink) | |
humanum est errare
David 2003 #48853 EX-L RES Sage Brush Pearl [sold 3/10/09] 2009 Sienna XLT Limted AWD 2006 A4 2.0 CVT 2004 X3 3.0 2003 M3Cic 2003 325i (gone) 2003 Matrix XR (total loss) 1996 Landcruiser (gone) |
#10 (permalink) | ||
#11 (permalink) | |
Ferdspeed3
