Super Duper Member
I read through the manual and it looks very simple enough to do, even for someone like me. However, I also read somewhere else that checking out the timing belt was a very simple task but when I attempted it, there were a couple of "gotchas" I wish someone had told me about when taking off and on the cover. Is there anything I should be informed of when changing the air filter JICIMFU?
Also, can someone please tell me exactly what this part, circled in red, is and what its function is? And how tight is the steel band that keeps the part in red attached to the big tube supposed to be tightened? If it was too obvious, sorry. Thanks. |
#2 (permalink) | |
2003 SS EX-L RES
Good Luck! |
#3 (permalink) | |
Super Duper Member
Admin Du Jour ®
The air filter is an easy replacement, but many of us X owners have found the screws/bolts are REALLY REALLY REALLY tight from the factory. There are 4 IIRC. They're also pretty far down there. I tried a 10" or 12" phillips screwdriver but couldn't get enough torque to loosen them. They have a bolt head, so I'd suggest a ratchet extension.
Oh, and a magnetic one at that -- you don't want to drop them
![]() ![]() ![]() ![]() Join Date: Oct 2002
Super Duper Member
Super Duper Member
Just my $.02.... |
anybody who has done air filter replacement , how did you fix the spring around the air tube.. the spring is so tight that i cant even close it aorund the tube. The part number is 8(eight) in the diagram posted by riprock
Sage brushpearl 2003 EX-L , Cargo tray |
Rip Tide Dude!
I just removed the 4 bolts attaching the top cover of the filter box using a long extension, ratchet and an 8mm socket to replaced the air filter.
John, I actually couldnt lift the top cover without removing the side air tube connected to the top cover. There is a spring around the air tube and i had to remove it to pull the top cover out. I couldnt replace the spring back as it was very difficult to pull the ends together. any suggestions will be appreciated. Is it safe to drive without that spring ??
#13 (permalink) | |
Super Duper Member
#14 (permalink) | |
Super Duper Member
#15 (permalink) | |
Guest
Posts: n/a
. Thank you for putting this out there for all of us!
