Idle Air Control Screws - Honda Pilot - Honda Pilot Forums
Old 01-07-2013, 02:40 PM   #1 (permalink)
Default Idle Air Control Screws
Wife's 2003 Pilot has been having the surging RPM issue for a while and has finally thrown the P0505 code. So, with 150K on the odometer and never a cleaning the throttle body I figure I will go ahead and take it apart to clean the TB and IAC at the same time.
Question here is does anyone happen to know the screw size on the IAC? It looks like a Torx or Star type bit but I am not sure of the size.
05220713 is offline   Reply With Quote
Old 01-07-2013, 10:21 PM   #2 (permalink)
If it is like other Hondas, might be 5 point screw. Don't have a bit for that? Use a dremel or hack saw to make a groove for a flat screwdriver.
archie is offline   Reply With Quote
Old 01-27-2013, 04:53 PM   #3 (permalink)
Does a 2005 pilot have an Idle Air Control Valve?
I took the intake butterfly valve off to clean it but did not find the IACV that is suppose to be attached to it. May be a picture would help. Thanks in advance!
StudentPilot is offline   Reply With Quote
