Having trouble determining which direction the crank bolt needs to turn to remove it! Think its clockwise but not positive and it is tight, don't want to strip anything, stalled out waiting on an answer, anyone?
2005 Red Rock Ex Pilot 2011 Bali Blue Pearl EX-L RES |
Ok thanks, 1/2" impact is not getting it and I just broke a 1/2" extension using a breaker bar, not sure now. Soaked it in oil and regrouping now, maybe some heat on the bolt?
No under drive pulley, bad timing tension pulley I think the timing belt is loose!
I used a breaker bar with two 4 feet pipes for more torque and just barely broke it loose on a Civic engine.
Crank bolts are really really tight. Sent from my iPhone using AutoGuide.com Free App |
READ THE ENTIRE POST BEFORE DOING THIS.
Use the starter to bump the motor with a breaker bar attached to the crank bolt. Works every time. Use some rope to secure the breaker bar to the lower control arm or sub frame. When you bump the starter, the bar will rotate slightly until it hits the frame. YOU MUST DISABLE THE IGNITION SO THE ENGINE DOESN'T ACTUALLY START. I do this by unplugging the 6 ignition coils and pulling the fuel pump fuse. |
#9 (permalink) | |
A 1" impact gun is great but if your using the little 1/4 air hose that comes with most compressors, you won't get anywhere near the max torque.
You'll need at least a 3/8", possibly even 1/2" hose to get the most out of that impact gun. |
Ok regrouped mostly due to the fact that I figured out the power train warranty will cover the repair to 60,000 miles, that and it's the wife's primary wheels with the kids. Different story if it was a beater I drove.
So got it in to the dealer today to fix, will let you all know what they find. Thanks for the great ideas, will have to try that starter idea the next time I have to pull a dampner off an engine. Guess those little starters can put out the torque! My luck I would tear teeth off the flywheel! Thanks again for all the replies. Have a 3/8" hose and just figured I better not press my luck! Had to leave for work the next day for a week and did not want to try to figure out how to drill out what was left of a bolt the clean threads!
2005 Red Rock Ex Pilot 2011 Bali Blue Pearl EX-L RES Last edited by North_Pole_Pilo; 01-08-2013 at 12:09 AM. Reason: Added information on the air hose and gun |
