Mixing synthetic trans fluid ??? - Honda Pilot - Honda Pilot Forums
Old 12-22-2011, 09:43 AM   #1 (permalink)
Default Mixing synthetic trans fluid ???
Hi Folks, just finished changing engine oil, vtm-4 oil, and transmission oil. At the third litre of oil during refill i realized the dealer gave me a Honda synthetic oil as opposed to the regular oil, I took it for a ride and all seems ok. has anyone else mixed the two oils and what were your results>>> thanks in advance.
goneb4u is offline   Reply With Quote
Old 12-22-2011, 10:10 AM   #2 (permalink)
dustino8's Avatar
When you refer to synthetic vs regular, are you talking engine oil or transmission oil? Either way, I wouldn't be concerned. Honda recently changed the semi-syn tranny fluid to full synthetic (ATF Z-1 to ATF DW-1). It is said to be compatible.
Edit: oops, just noticed trans fluid in the title.
2007 Toyota Tundra
Old 12-22-2011, 10:13 AM   #3 (permalink)
RSQ Pilot's Avatar
Garage
Honda Z-1 and DW-1 ATF fluids are intermixable in Honda transmissions designed for Z1. Normal ATF service only removes approx. 3 quarts. I used the new fluid, DW1 at 33000 miles. No problems.
Old 12-22-2011, 10:55 PM   #4 (permalink)
hi gone, is it easy to remove the vtm4 fill and drain plug?
Old 12-23-2011, 02:04 AM   #5 (permalink)
Yes - but that fluid is for the rear diff only.
Old 12-23-2011, 10:06 AM   #6 (permalink)
Use a 3/8" extension to remove fill and drain vtm plugs. i put the pilot on jack stands to make it easier to access the rear diff, it helps when refilling as well, I used a drill pump to fill.
Old 12-23-2011, 10:23 AM   #7 (permalink)
PLEASE (for your own sake) use a new, or very clean pump and hose for filling the VTM unit.
The system is very sensitive to fluid contamination, and there have been reports of problems from as little contamination as using the same pump for regular gear oil, even though it appeared to be empty of residual fluid.
You do not need a drill pump. a cheap gear oil pump works just fine.
Old 12-23-2011, 10:32 AM   #8 (permalink)
"PLEASE (for your own sake) use a new, or very clean pump and hose for filling the VTM unit.
You do not need a drill pump. a cheap gear oil pump works just fine. "
Good points I should have mentioned, my drill pump is used strictly for the vtm refill (4 times now), I hang it on the wall in teh garage to avoid contamination, it was less than $10 and literally takes less than one minute to refill.
Old 12-23-2011, 10:34 AM   #9 (permalink)
Forgot to mention for those with chain saws, the vtm oil is so clean to the eye i recycle it as chain bar lube on my chain saw, works great.
Old 01-01-2012, 10:10 AM   #10 (permalink)
samc's Avatar
Again You can add that new DW1 synthetic stuff if you have normal Z-1 non-synthetic sitting in your tranny but not vice versa. Such as the newer pilots come with DW1 only I believe. Don't be throwing in some old bottles of Z1 fluid just to save a few bucks.
