60,000 mile maintenance - Honda Pilot - Honda Pilot Forums
Old 07-26-2011, 03:11 PM   #1 (permalink)
Question 60,000 mile maintenance
New member w/ a 2006 Pilot bought used. Does anyone know what the maintenance minder will be at 60,000 miles on a 2006 Pilot? I need to have that maintenance completed before I leave for a road trip and the owners manual doesn't specify maintenance by mileage, only by maintenance minder numbers. I'm thinking tranny fluid, coolant, air filter & oil/filter.
Skipper is offline   Reply With Quote
Old 07-26-2011, 03:24 PM   #2 (permalink)
Negative on the coolant, it should last 105K miles on the OEM coolant. I would drain and refill the tranny fluid, cabin filter, oil and filter and maybe the rear diff fluid, that is if you have a rear diff.
Old 07-26-2011, 03:48 PM   #3 (permalink)
roarkrd's Avatar
Just a reminder, if you do have the 4wd option and decide to change your fluid, be sure to use Honda's VTM-4 fluid and not DPF2 or any other brand.
Old 07-26-2011, 07:43 PM   #4 (permalink)
samc's Avatar
Do you know the history of your car?
If not then I would do a full circle
Oil change w/ filter
tranny fluid
differential fluid
vtm-4 fluid
air filter
cabin filter
and check brake/coolant/Power steering fluids for level.
edit: And the most important one, washer fluid.
Old 07-27-2011, 10:57 AM   #5 (permalink)
All points above are excellent. I would recommend the full tranny 3 change process. You don't know how the other guy drove it.
Then add an external tranny filter and cooler and you are ahead of the game.
Have a great trip.
2005 Honda Pilot EXL
2003 GMC Envoy XL
2002 Toyota Highlander
1993 Mercedes 600SL
I am lost when there is no grease under my finger nails.
playstrings is offline   Reply With Quote
