Tire Sizes - Honda Pilot - Honda Pilot Forums
Old 02-06-2003, 01:25 PM   #1 (permalink)
gksmith's Avatar
Default Tire Sizes
I'm not overly keen on the tires my Pilot came with so I am considering replacements. I like what I have read about the Michelin Cross Terrain SUV and will probably get a set of those.
I have some questions about tire sizes. Unlike somethings, in tires, size does matter!
discounttiredirect.com shows several sizes that will work on the Pilot. They list the original size, +0, +1, +2, and +4 sizes.
+0 doesn't seem to get you anything over the O.E. versions. Will +1 work with the Pilot rims or are new ones needed?
I expect +2 and +4 require new rims. Would they provide much better handling than the +1s?
My local warehouse club has the O.E. size at $125 installed and balanced.
<P><BR><P><APPLET NAME="marquee" CODEBASE="http://home.rochester.rr.com/ngsmith/Java/" CODE="Marquee.class" WIDTH=370 HEIGHT=206>
<PARAM NAME=message VALUE="GKSMITH's Vehicle;Sage Brush Pearl EX-L RES;Installed Options;Lower Trim/Fog Lights;Running Boards;Rear Splash Guards;Air Deflector (rev. 2);Cross Bars for Roof Rails;Auto Day/Night Mirror;Cargo Organizer;Cargo Cover;Weather Tech mats;Silver EX Emblem;Yakima Load Warrior;Vent Visors #94744;HONDA-PILOT.ORG Sticker;Alpine CHA-S634;Alpine XMA-T200RF">
<PARAM NAME=delay VALUE="10;10;10;10;10;10;10;10;10;10;10;10;10;10;1 0;10;10;10">
<PARAM NAME=font_size VALUE="24;24;24;24;24;24;24;24;24;24;24;24;24;24;2 4;24;24;24">
<PARAM NAME=textcolor VALUE="0 255 0;255 255 0;0 255 0;255 255 0;255 255 0;255 255 0;255 255 0;255 255 0;255 255 0;255 255 0;255 255 0;255 255 0;255 255 0;255 255 0;255 255 0;255 255 0;255 255 0;255 255 0">
<PARAM NAME=animation VALUE="3 2000 3;3 2000 3;3 2000 3;3 2000 3;3 2000 3;3 2000 3;3 2000 3;3 2000 3;3 2000 3;3 2000 3;3 2000 3;3 2000 3;3 2000 3;3 2000 3;3 2000 3;3 2000 3;3 2000 3;3 2000 3">
<PARAM NAME=Backgroundimage VALUE = "http://home.rochester.rr.com/ngsmith/images/Big_Honda_Pilot.gif">
</APPLET>
gksmith is offline   Reply With Quote
Old 02-06-2003, 01:42 PM   #2 (permalink)
vellinga's Avatar
Check out Tirerack.com for the specs on the tire(s) that you are considering. They provide much detail on all aspects of the tires, including what rim widths are required for various tire sizes.
I thought about sizing up when we buy Cross Terrains, but it looks like the 255 size that I'd like will require a wider rim.
Rob
2003 Honda Pilot EX-L RES
Nighthawk Black Pearl
All-season mats, Rear mudguards, Cargo tray, Separation net, Thule 754xt cross bars (Thule Mountaineer rooftop box, and many attachments), Honda-Pilot.org sticker, Pirelli Scorpion STR-A's (gone), Falken tires, KYB struts and shocks, Drilled Axxis rotors, OEM Hitch, Allen Racks 540RR Bike Rack
2000 BMW 540i Sport Touring (a.k.a. wagon)
1989 Volvo 740 GL Wagon (donated; replaced by 540iT)
1989 Volvo 240 DL Wagon (donated; replaced by Pilot)
vellinga is offline   Reply With Quote
Old 02-06-2003, 01:48 PM   #3 (permalink)
Default Plus sizes
Each "+" is adding an inch to the wheel diameter.
All "+" sizes need new rims.
These type of tire changes on an SUV are more for looks and style than for function. (OK; start shooting)
I would stay as close to the factory size as practical unless you have a specific reason to change a parameter.
Larger wheels make for smaller sidewalls and reduces flex in cornering. Also increases ride harshness.
Larger width increases tire patch (to a point), increases flotation for soft surfaces, increases width of tred for loose surfaces.
Also decrerases contact PSI which adds to hydroplaning, and increases roaling resistance lowering MPG.
Larger total diameter raises ground clearance, increasases atach and departure angle. Also rasies gear ratio (less usable power), raises center of gravety (less stability).
Talk to the guys at Tire Rack, and have fun.
Old 02-06-2003, 03:03 PM   #4 (permalink)
While we're on the subject of tires/rims does anyone know FOR SURE if the Xs larger 17 inch rims and tires would fit on the Pilot? I know the bolt pattern is suppose to be the same but question if the X rim would fit snug against the hub with appropriate clearances all around - steering gear, calipers, rotors, etc. plus wheel-well clearance. An Acura dealer (parts guy) told that they have determined that some Acura wheels with same bolt patterns are not interchangeable because of differences in the rim - said the only way to know was the acid test - try putting one on. But, I have a slight problem with that - no X. And, I'm afraid that if I just approach someone with an X and asked them if I could take a wheel off to try it on a different vehicle that person would probably think, at best, that I was working for Candid Camera!
seadog is offline   Reply With Quote
Old 02-06-2003, 03:09 PM   #5 (permalink)
vellinga's Avatar
So take your friends suggestion back to him and ask if they have any 'spare' X rims around their dealership to try on for size.
Where do you plan to buy the 'X' rims from? dealership? eBay? MDX.org? Tim/acuraworld?
Old 02-06-2003, 03:13 PM   #6 (permalink)
Originally posted by seadog
does anyone know FOR SURE if the Xs larger 17 inch rims and tires would fit on the Pilot? . . . . . An Acura dealer (parts guy) told that they have determined that some Acura wheels with same bolt patterns are not interchangeable because of differences in the rim . . . . .
I think that has more to do with early Acura's like Integras and such.
I would start with Tire Rack, and see if they recommend a different wheel from Pilot vs. MDX
If the same aftermarket rim fits, then I would be 99% sure the same factory rim would fit.
Old 02-07-2003, 07:02 PM   #7 (permalink)
Birdman's Avatar
The site below is a calculator to compare diameter, width and associated parameters of various size tires/wheels.
http://www.miata.net/garage/tirecalc.html
Birdman is offline   Reply With Quote
Old 02-07-2003, 07:33 PM   #8 (permalink)
humanum est errare
Thanks - nice tool
David
2009 Sienna XLT Limted AWD
2006 A4 2.0 CVT
2004 X3 3.0
2003 M3Cic
2003 325i (gone)
2003 Matrix XR (total loss)
1996 Landcruiser (gone)
