Transfer Fluid - Honda Pilot - Honda Pilot Forums
Old 05-04-2011, 05:48 PM   #1 (permalink)
Default Transfer Fluid
The manual says replace transmission and transfer fluid. What is the transfer fluid?
jimel is offline   Reply With Quote
Old 05-04-2011, 07:44 PM   #2 (permalink)
Transfer case. Transfers engine power to rear differential in a 4wd vehicle.
2005 LX 4wd
OEM accessory roof bars
OEM nerf bars
OEM rear splash guards
2006 OEM 4wd emblem
Garmin GPS
Aftermarket tinted windows
OEM accessory fog light kit
OEM accessory cargo cover
Silver painted grill
Acura stainless exhaust tips
KYB GR2 struts/shocks
Curt 13328 Hitch
Old 05-05-2011, 09:21 AM   #3 (permalink)
I just found this out for myself. Here's a link to show you where it is My A136 maintenance experience - Honda Ridgeline Owners Club Forums
pilotlite is offline   Reply With Quote
Old 05-14-2011, 09:40 AM   #4 (permalink)
samc's Avatar
Good link.
But use the $2 hand pump available from walmart, autozone, etc.... Makes the job atleast easier.
Old 05-31-2011, 10:55 AM   #5 (permalink)
anybody like mobil 1 75w-90 for this?
I know the manual calls for 80-w90, but having a hard time finding 80w-90.
Also is a full synthetic okay in this transfer case. I have read where some transfer cases do not perform well on full synthetic as it is "too slippery," which kind of souinds like pure internet bee esss, but there may be some truth behind it.
Old 05-31-2011, 11:23 AM   #6 (permalink)
krazykarguy's Avatar
Since this particular transfer case does not contain clutch packs or limited-slip capability of any real substance, any 80W-90 will be fine. No need for synthetic oil.
If you can't find 80W-90, you're not looking hard enough, although there is little difference between 75W-90 and 80W-90 except for cold flow dynamics.
Old 06-01-2011, 01:50 PM   #7 (permalink)
samc's Avatar
How much truth is there to the weight of the fluid? I remember in another thread that someone used 75w-90 mobil1 in their pilot and it worked just fine. Now I'm reading about 80w-90 above. Can someone separate chime in?
Old 06-01-2011, 08:33 PM   #8 (permalink)
75W-90 is just fine if not better.
