Power Steering Filter/Reservoir Cleaning - Honda Pilot - Honda Pilot Forums
Old 04-18-2011, 12:16 PM   #1 (permalink)
Default Power Steering Filter/Reservoir Cleaning
My Power Steering pump (2003 Pilot) has had a "whine" for a few years, even though the fluid level is correct. I just bled and replaced the fluid (Honda fluid) hoping to fix the noise, but no luck.
Next step is to replace the reservoir, which contains a built-in filter. I've read that this filter gets gunked up and can cause whine.
Before I buy a whole new reservoir, has anyone had any luck cleaning out this filter?
StuGee is offline   Reply With Quote
Old 04-23-2011, 04:58 PM   #2 (permalink)
Smile power steering whine / noise ' Pilot 03
Just a follow-up to anyone with a noisy power steering whine:
I picked up a new PS reservoir from the Honda dealer for about $22.00, plus two 12 oz bottles of Honda PS fluid for another $20.00. (The new reservoir has no filter that I can see, and has a slightly different design.)
Bottom line: After installing the new reservoir, re-bleeding the lines for air bubbles, and topping off... the noise has disappeared.
Well worth trying this fix before spending big bucks on a new pump.
(**One tip: After topping off and running the engine, turn it off and let it sit for a while to let the remaining air in the system will dissipate, and the noise goes away.)
Old 04-23-2011, 05:37 PM   #3 (permalink)
cofetym's Avatar
Thanks for sharing and I'm glad that worked out for you.
____________
2005 EX-L 4wd
