Sticky accelerator/lunging from stop? - Honda Pilot - Honda Pilot Forums
Old 03-08-2011, 10:36 AM   #1 (permalink)
Default Sticky accelerator/lunging from stop?
I have been having problems with my 2004 EX for quite some time now with what seems to be a sticking accelerator pedal. It seems that when I accelerate from a stop, the pedal seems to stick a bit and having to press it a bit harder to get it to move causes the truck to lunge a bit from a stop. Anybody else dealt with this or know what it might be caused from? Thanx.
wburgpilot is offline   Reply With Quote
Old 03-08-2011, 11:08 AM   #2 (permalink)
The 04 has a cable controlling the throttle unlike the 05 that went to electronic control.
My initial suggestion is to remove the cable, clean and remove any signs of rust, lube then reinstall it. I've had two cars where I had to do that on.
Old 03-08-2011, 05:48 PM   #3 (permalink)
The problem is most often caused by gunk and varnish on the throttle blade which makes the throttle blade stick to the throttle body bore when closed, requiring extra pedal effort to unstick when accelerating from a dead stop. What I do to clean it is to spray some carb cleaner on a rag or paper towel and clean the front outer edges of the throttle blade while holding it open. Also, get under/behind the lip in the throttle body that touches the front of the throttle blade when it is closed. You will see lots of black crud on your rag/paper towel. Keep cleaning till your rag comes out clean. Warning, do not spray inside the throttle body as you risk destroying the throttle position sensor (TPS) or other delicate electronics.
2005 LX 4wd
OEM accessory roof bars
OEM nerf bars
OEM rear splash guards
2006 OEM 4wd emblem
Garmin GPS
Aftermarket tinted windows
OEM accessory fog light kit
OEM accessory cargo cover
Silver painted grill
Acura stainless exhaust tips
KYB GR2 struts/shocks
Curt 13328 Hitch
