What Motor Oil For your pilot? - Honda Pilot - Honda Pilot Forums
Old 03-04-2011, 11:13 PM   #1 (permalink)
Default What Motor Oil For your pilot?
Just Brand NAme and weight you use or like for your Pilot. Also filter brand.
This could be a good thread.
Old 03-04-2011, 11:24 PM   #2 (permalink)
Yeah, just like the other 100s of threads of a similar nature that are on this forum already.
Old 03-05-2011, 07:40 AM   #3 (permalink)
onu2002's Avatar
5W-20. Whatever the oil & filter special is at Advance or Autozone.
Tom
2003 Honda Pilot EX
2004 Honda S2000
2006 Hyundai Sonata GLS
onu2002 is online now   Reply With Quote
Old 03-06-2011, 09:13 AM   #4 (permalink)
samc's Avatar
Why not...
I use Mobil 1 5w-20 when I can find it otherwise 5w-30 same.
And usually one of the following filters: mobil1, oem, fram, or purlator. Basically whichever I find on sale.
Old 03-06-2011, 02:31 PM   #5 (permalink)
94eg!'s Avatar
Mobil-1 0w20 will provide better cold start protection because the oil is thinner when cold. This also helps a little with fuel economy. Still not available in a 5qt jug though. Until it is, I'll be using M1 5w20.
I also use M1 filters, but I'm thinking about going to something less expensive. Not Fram or Honda A02 Honeywell filters (because of the cardboard end caps).
Honda A01 vs Fram Cheapo (same as Honda A02):
Nicer Honda A01 after 5k miles (yikes) vs Mobil-1 after 5k miles:
Old 03-06-2011, 02:40 PM   #6 (permalink)
jpc
I purchased Chevon 5w-30 from costco when it was on an in-store rebate. Oil is oil to me so long as I know the name. When it comes to oil filters, I always use Honda. I know it costs more but I wonder if others do so too.
jpc is offline   Reply With Quote
Old 03-06-2011, 03:29 PM   #7 (permalink)
94eg!'s Avatar
Honda A02 filters are junk. They are made by Honeywell (Fram). Same thing as the one I pictured on the top right, except it has a silicon drainback valve...
Old 03-06-2011, 03:31 PM   #8 (permalink)
aenergy's Avatar
I use mobil clean 5000 5w-30...
but I change the oil every 2.5-3k miles..
aenergy is offline   Reply With Quote
Old 03-06-2011, 03:32 PM   #9 (permalink)
jpc
Yi! What filter do you use? The mobil 1 above looks good compared to the Honda.
Old 03-06-2011, 03:36 PM   #10 (permalink)
Castrol 5w30 and WIX 51334 The old large standard that the 04 came out with.
Old 03-06-2011, 03:37 PM   #11 (permalink)
94eg!'s Avatar
Yes i have been using the Mobil 1 M1-110 filter or the M1-104. Either one works on the pilot, but they cost more and more each year. Walmart used to carry them for $9.99, but stopped over a year ago. Everyone else sells them for $13.99 or more.
PS: Here is a pic of a Honda A02 filter cut open. See how it's identical to the orange Fram (cardboard end-caps) but with more pleats and a upgraded silicone drainback valve. It might get the job done, but I don't like the idea of cardboard end-caps:
The Honda one I posted earlier is an A01 part number, but they were discontinued a long time ago. Very difficult to get ahold of. They are better quality, but still weak compared the most brands that have the metal end-caps.
Old 03-06-2011, 03:46 PM   #12 (permalink)
KKL
I use Walmart (SuperTech) filter and the cheapest 5W-20 available in the store.
KKL is offline   Reply With Quote
Old 03-06-2011, 06:47 PM   #13 (permalink)
xGS
xGS's Avatar
The Fram extended guard (XG) series of filters have metal end caps:
Old 03-06-2011, 08:35 PM   #14 (permalink)
94eg!'s Avatar
Yes, and very few pleats. That means very little filter media...
Old 03-06-2011, 10:24 PM   #15 (permalink)
xGS
xGS's Avatar
Mobil 1 M1-110 is second from left - enough pleats for you, or not?
