Removing Panel - Honda Pilot - Honda Pilot Forums
Old 02-01-2011, 10:32 PM   #1 (permalink)
stevek2010's Avatar
Default Removing Panel
I'm wanting to remove the panel that has the power connector. I want to remove this so I can run my Navi power cables behind it and run the cables in and down then enter the center armrest to connect to the charging port in there. No wires exposed, clean and crisp.
stevek2010 is offline   Reply With Quote
Old 02-01-2011, 11:04 PM   #2 (permalink)
cofetym's Avatar
This might help:http://www.installer.com/pdf/99-7876.pdf
____________
2005 EX-L 4wd
Old 02-02-2011, 12:37 PM   #3 (permalink)
stevek2010's Avatar
Thanks. It helped a bit. I mostly just went with it and popped it off. Was a lot easier then expected. Went back on with a snap too.
Made a huge difference. Made a small hole at the top for the wire and ran it all the way down to the center console.
Old 02-02-2011, 12:49 PM   #4 (permalink)
cofetym's Avatar
Looks sharp.
____________
2005 EX-L 4wd
