What to do at 67,000 on a 2007 - Honda Pilot - Honda Pilot Forums
Old 10-07-2010, 09:41 AM   #1 (permalink)
Default What to do at 67,000 on a 2007
My sister and her husband recently divorced, unfortunately. He took care of the 2007 Honda Pilot EXL 4WD. Unfortunately, he didn't keep records and he did keep the owners manual. Anyway...
She just had all new brakes installed at all 4 corners -- pads/hardware and turned rotors, along with a brake flush for $366. Seemed like a great deal with a lifetime labor warranty and 1 year on parts.
What else needs to be done outside of the cabin filter, which was done, oil changes and tire rotations/balance/alignment? She has new tires on that have about 15k on them and she has the lifetime alignment from Firestone where she has most of the service performed.
I am thinking the ATF and differential fluids have never been changed. She isn't mechanically inclined and I'm not close enough to do it for her. What is she looking at for those services?
Anything else?
Many thanks in advance!
Shumax
shumax is offline   Reply With Quote
Old 10-07-2010, 10:34 AM   #2 (permalink)
2007 have a Maintenance Minder system that tells you what to do and when.
Become familiar with the MM by referring to the Owners Manual and follow it's advice.
Old 10-07-2010, 10:45 AM   #3 (permalink)
Thanks! Long term, this looks like a good resource. In the short term, though, I need some quick help as she has the time and money to handle this over the next two weekends.
Thanks!
Old 10-07-2010, 12:48 PM   #4 (permalink)
cofetym's Avatar
No need to use the dealership for routine maintenance. Find a good import shop that knows Honda's. Use Honda fluids everywhere with the exception of engine oil, choose your favorite 5w 20 weight. Biggest service is around 105k.
The owners manual and the search button on this forum will help.This is frequently discussed here.
____________
2005 EX-L 4wd
Old 10-07-2010, 05:37 PM   #5 (permalink)
Just so you guys saw, the first post said her husband took the owner's manual with him....
-Sam
samelcamel is offline   Reply With Quote
Old 10-07-2010, 06:07 PM   #6 (permalink)
To access the owners manual online, go to the Honda website and sign into the Owners resources section.
You can register your Honda, and read any part of the owners manual you want to. Here is where you can register and login:
https://www.ahm-ownerlink.com/login.asp?brand=honda
Old 10-07-2010, 07:59 PM   #7 (permalink)
A bit more here...she is in Charlotte, NC. Are there any independent shops in that area that any of you know of that work on Honda's, primarily? I'll be there in a few weeks and may handle it for her if I know what all needs to be done.
Thanks!
Old 10-07-2010, 08:22 PM   #8 (permalink)
jl_ss's Avatar
As Rocky notes, the 2007 has a maintenance minder that indicates oil life left and any required services due. If it hasn't been reset and services are overdue, the MM will stay on and start counting negative miles. The services are indicated by the letter A or B and the numbers 1 through 6 (A1, B3, etc). You could ask your sister if this is the case. If nothing is showing due, it is likely up to date.
Secondly, if she knows which dealership her ex was taking it to, she can call the dealership and they can tell her everything that has been done and if it looks like anything was missed.
Old 10-07-2010, 08:23 PM   #9 (permalink)
onu2002's Avatar
If she can't find a shop that specializes in Hondas, any dependable shop will do. She can get the fluids at the dealer and supply them to the shop. I wouldn't doubt she'll have any troubles in Charlotte though.
Tom
2003 Honda Pilot EX
2004 Honda S2000
2006 Hyundai Sonata GLS
Old 10-08-2010, 04:41 PM   #10 (permalink)
samc's Avatar
Either way tell your sister to signup to this website. There are alot of knowledgible members here who can help you troubleshoot anything from a misfire to smoke shooting out of your engine.
Hell we can help you with other cars other then hondas.
But basically here are the codes below for the maintenance minder.
(Regardless of what code comes up tell your sister to always have the oil filter changed)
A= change oil and filter
B= change oil and
1 = tire rotation
2= air filter replacement
3= transmission oil replacment
4= spark plug replacement, valve adjustment and timing belt replacement
5= coolant replacement
6= VTM (4wd) differential fluid replacement
