Have you changed your cabin air filter? - Honda Pilot - Honda Pilot Forums
Old 09-27-2010, 08:06 PM   #1 (permalink)
Scratch's Avatar
Default Have you changed your cabin air filter?
If you haven't it might end up looking like mine. I bought this 2006 Pilot used just this month, and I've been going over it each night to track down any issues or problems and resolve them.
Since I have had vehicles with an in-cabin air filter, I knew this was something that needed to be replaced. Little did I know, this was not high priority for the previous owners. I knew I was in bad shape when I saw the plastic bar was still there.
The condition of the original filter, after 4 years of use, shocked me.
Have you changed your cabin air filter?-testing-001.jpg   Have you changed your cabin air filter?-testing-002.jpg
Old 09-28-2010, 12:50 AM   #2 (permalink)
Now you know why the previous owner didn't change it...because Honda makes it a real PIA the first time.
BE
'03 Pilot EX
'02 Highlander
'01 Civic EX
Old 09-28-2010, 01:59 AM   #3 (permalink)
Eww....gross.....
Old 09-28-2010, 06:46 PM   #4 (permalink)
ooooooooowwwwwwwwwwwwwhhhhhhhhhhhhhhhhhhhh.
Holy smokes. Mine was pretty nasty at 28k/2008 model, changed this July. Yours is non-functional. Wasn't it FUN changing it?!
OhioBobcat2000 is offline   Reply With Quote
Old 09-28-2010, 09:54 PM   #5 (permalink)
Xeption's Avatar
where is this filter located?
Xeption is offline   Reply With Quote
Old 09-28-2010, 10:19 PM   #6 (permalink)
Behind the passenger side glove box
Old 09-28-2010, 11:20 PM   #7 (permalink)
cofetym's Avatar
I really need to check mine.
____________
2005 EX-L 4wd
Old 09-30-2010, 08:11 PM   #8 (permalink)
samc's Avatar
I'm not sure if mine (2006 with 52k miles) was ever changed. Maybe I should go take a look this weekend .
Thanks for the heads up OP.
Old 10-09-2010, 11:21 AM   #9 (permalink)
Scratch's Avatar
it was not to fun changing it...and i need to check it out again, now when i turn on my headlights the small bulb under the "not an ashtray" stays on... grrr
but at least i have a functional filter again. *yuk*
Old 12-10-2010, 03:14 AM   #10 (permalink)
Default OEM Filter
Actually, while it's good that you've changed the filter, the stock filter is not as dirty as you might think.
The OEM filter is an active carbon filter that looks like this when new:
So compared to non-OEM replacement white paper filters from the Honda dealer and other auto parts stores, it certainly looks awful.
The best replacement I've found is here, which gives you great particle filtration and some amount of odor blocking as well. And it's about the same price as the ones at Advancezoneriley.
noanswer is offline   Reply With Quote
Old 12-10-2010, 03:19 PM   #11 (permalink)
That light is supposed to stay on when the headlights are on. It's off when the headlights are off. Perhaps you inadvertently "fixed" the light when you were in there.
deanmcneill is offline   Reply With Quote
