Without having a shop and a hoist do the work - how could one do a full fluid change on the Tranny in an 07 EXL 4wd ?
Tonight I did the 4 litre ATF change on mine, and I got to thinking of a way to maybe do the full change in the driveway - but I've no idea if it'll work. What if the fluid was drained, then the drain bolt tightened up. Start up the Pilot - foot on brake - and slowly go through the gears. Turn it off - drain again. Would this work to get more of the fluid out of the converter - or is this a sure fire way to smoke a trans? If this could work - the cycle could be done 3 or 4 times - draining all the fluid. I am probably way out on this one - but thought I'd ask if it could work? thanks.
Changes/Mods made so far: - Cabin Air Filter replaced - YUCK. - Dash lights revived vis a vis hand pounding on dash - not cool Honda. - Class III Trailer hitch installed - wiring as well - ATF change done - badly needed - VTM fluid change completed - H9 bulbs put in - H11's out |
I've done all of my own maintenance to date but the tranny fluid. My dealer wanted about $85 to do it. Otherwise you need to drain and drive three times to flush it if I remember correctly. Wasn't worth the time and amount of tranny fluid for me to do it myself.
Might work, might cause issues.
If you really are worried (I would only be worried if the fluid was burnt or contaminated), then you can drain and fill from the cooler line. There are systems that put clean new fluid in as the old fluid is drained.
I'm no fan of the forced draining of any auto transmission. There are many that say forced draining causes damage to the unit.
The rule of thumb is that about 1/3rd of all the transmission fluid comes out during a change. the rest being held inside. I did once on my truck, do a drain and refill, three times in quick succession but it made no noticeable change in the way the box operated. It was a waste of time. So all I do now, is drain and refill at half the recommended intervals. No transmission failures in over 600k of driving in last 20 years.
I would not do a forced change.
Let the system pump out he oil, and the changing setup delivers the same quality to the return line. Again, all not usually needed.
