Last time my Pilot 2003 was in the dealership the service man told me the rear brake pads were thin like 2mm - he gave me a quote but I decided to shop around first -
Can anyone tell me how much usually a brake job (replacing brake pads) cost? FYI, I am living in Chicago Suburb, living cost here gas price is about $2.90 now days. Thanks. |
As said 10 different answers...
But where do you live that you would pay $100 an hour other then a dealership? ![]() Anyway $50 for the pads and an hour seems right. Although if you had even the slighest bit of mechanical skill then you can tackle this job yourself. All you need is a c-clamp, some anti-seize, sockets and your pads. Just one advice whether you get it done in the shop or not don't buy cheap pads. |
I'll second that. I just replaced the pads, front and rear, on my Pilot. The pads cost me a little over $100 (OEM Honda pads). The only tools I needed were a socket set and a C-clamp. The anti-seize goo was included with the pads. From start to finish, the job took me under two hours, and I was moving pretty slow because I was on blacktop in direct sunlight the whole time.
2008 Honda Pilot VP 4WD 2009 Volkswagen Jetta 1988 Mercedes-Benz 300E |
Just my 2 cents. I know very little about automobile maintenance and changed all four of my pads for less than $120 with no problems. For the front and back, my local dealer was going to charge me close to $500. The toughest part is carefully jacking. IMHO, Honda has put a lousy jack point close to the rear end of the vehicle.
It's about a 1/4 piece of steel. My vehicle tottered enough to scare the sheet out of me until I got stands under each pinch weld. Once on the stands I was good to go. Know anything about changing plugs? That's my net endevour.
