What would you have done at 105K? - Honda Pilot - Honda Pilot Forums
Old 06-15-2010, 04:24 PM   #1 (permalink)
Default What would you have done at 105K?
I do many things DIY. But I don't want to do the timing belt and water pump on my wife's 2006 EX-L. I have done brake shoes, ATF, etc.
What else would you have done? I am thinking:
1. timing belt
2. water pump
3. drive belt(s)
4. radiator hoses
The manual seems to say spark plugs are due. Easy to do at home? Or have the mechanic do it?
Any cost estimates on the TB/WP service?
2006 Pilot 2WD EX-L, Desert Rock
2006 Ridgeline RTL, Steel Metallic Blue
2004 Element 2WD EX
hofffam is offline   Reply With Quote
Old 06-15-2010, 04:54 PM   #2 (permalink)
If you pay someone, $1400 for everything.
I'm actually thinking of trading as tires are coming up for replacement as well......
Old 06-15-2010, 05:10 PM   #3 (permalink)
jl_ss's Avatar
1. timing belt
2. water pump
3. drive belt(s)
4. radiator hoses
TB/WP is $750 at my dealer. For everything due in the manual including TB, WO, belts, SP, tranny fluid, inspect valve clearance, etc, my dealer wanted $1300.
Old 06-15-2010, 06:08 PM   #4 (permalink)
$750 to 800 for the TB/WP which includes your other belts and coolant change. There are some threads on the plugs. Dealer will charge about $200 for new plugs installed. There is a DIY thread on the TB/WP, but its still a complicated procedure. Brakes are about as comlplex a job as I would want to do.
- Colgen Full front end bra
- Sherpak Go-7 luggage pack
- AVS sun roof windflector
Old 06-16-2010, 02:42 PM   #5 (permalink)
onu2002's Avatar
This is the quote I got from my dealership:
TIMING BELT PACKAGE- INC. TIMING BELT, WATER PUMP, DRIVE BELTS, TIMING BELT TENSIONER, COOLANT, AND LABOR 950.00 +TAX+SS
SPARK PLUGS- 249.002+TAX+SS
BRAKES FLUID- 55.00+TAX+SS
VALVES- RARE TO BE NEEDED BUT RUNS 450.00+TAX+SS + GASKETS ~(50.00)
COMPLETE PACKAGE- 1429.00+TAX+SS INCLUDES, T-BELT PACKAGE, OIL CHANGE, TIRE ROTATION, BRAKE FLUID CHANGE, SPARK PLUG REPLACEMENT, SERVICE THE BRAKES, LUBE LATCHES, HINGES, SEALS, WINDOW RUN CHANNELS, ROAD AND SAFETY CHECK
SS=Shop Supplies=6% of labor up to $20.
I'll be getting an independent shop to do the belts, wtr pump & brake fluid, and I'll do the rest.
Tom
2003 Honda Pilot EX
2004 Honda S2000
2006 Hyundai Sonata GLS
Old 06-24-2010, 03:31 PM   #6 (permalink)
Default spark plugs, etc
Rocky,
What kind of tires do you run? I get an average of 86,000 miles on Michellin Cross Terrains from Costco (with pretty much ignored care) on my 03 Pilot. It is in today at 219,000 miles getting a timing belt.
billaubrey is offline   Reply With Quote
Old 06-25-2010, 02:04 AM   #7 (permalink)
Groundpound4200's Avatar
I used to have an Acura MDX and I brought it in to the dealer with about 140k on it for maintenance and left with an $1100 bill. They flushed the tranny, radiator, replaced the timing belt, water pump, spark plugs and wires IIRC. I can't think of anything else that was done..
Groundpound4200 is offline   Reply With Quote
Old 06-26-2010, 04:14 AM   #8 (permalink)
xGS
xGS's Avatar
See below:
Old 06-26-2010, 12:55 PM   #9 (permalink)
jl_ss's Avatar
Originally Posted by xGS View Post
See below:
Betcha they find other stuff to recommend to try to make up the difference...
