Transmission Question - Honda Pilot - Honda Pilot Forums
Old 05-04-2010, 09:02 AM   #1 (permalink)
Default Transmission Question
I know that this question has been addressed in some threads, but I am anal and need a more in-depth answer.
I am trying to ensure that I have the correct amount of tranny fluid in my 05' Pilot. The manual that I have (bootleg cd for 03' pilot shop manual) says to get the vehicle to normal operating temperature, park on level ground, shut it off and check the level within 60-90 seconds.
1) Is this the correct procedure for a 2005?
2) Also, it seems like right when you shut it off the fluid begins to drip down into the pan. If you check it right away it reads a little low and if you check it at the end of the 90 seconds it reads a little high.
Any insight into this would be greatly appreciated.
JDESIGNS is offline   Reply With Quote
Old 05-06-2010, 08:28 PM   #2 (permalink)
Can someone at least verify that this "60-90 seconds" is the procedure in the OEM service manual?
Old 05-06-2010, 09:09 PM   #3 (permalink)
Correct, turn it off, check it as soon as you can.
http://hondapilot.bkwon.net/manual/2005/
Page 204
