#16 (permalink) | |
2004 EX-L; Sage Brush Pearl; 5000K HID's; 6% Tint |
#17 (permalink) |
How do you figure you "saved" anything? ATF drain and fill and VTM-4 fluid would have cost you $40-$45 to DIY. You paid someone $60 to do 1/2 worth of work. $120/HR is enough for me to lay on my back for a few minutes.
#19 (permalink) | |
#20 (permalink) | |
VTM-4 fluid is $20 + oil change/filter with Mobil 1 is $30, ATF is $20, washers are another $4, pump $5. For about $80 you can do those 3 and if you want to blow another $15, you can get some Mobil 1 gear oil and another pump and do the transfer case too. DIY is so easy on these cars it makes it an easy decision if you are up for getting a little dirty. |
#21 (permalink) |
Not sure if this goes here but couldn't find another dealer/stealer thread. I do all the maintenance on my pilot except for oil changes and everytime I get the oil changed they recommend chaning something as it's dirty etc. Well the next time I got my oil changed I changed the transmission fluid and brake fluid right before I went to the dealer. Anyway...same story...told me that the transmission fluid and brake fluid were dirty and needed replaced. I said just changed it and they didn't seem to care. Anyone else have similar experience?
#23 (permalink) |
The local Goodyear tells me the same thing just about every visit for both my Pilot and Liberty. They also insist that the transmission should be power-flushed. I thank them for their concern (I only pay $16 for an oil change) and leave. It's not worth the argument. Oh, they were also the ones that said the Tire Pressure Monitoring System needed to be reset when new tires were installed. My response to that was not quite as polite.
2007 Pilot LX 2004 Suzuki V-Strom |
#24 (permalink) | |
(it was a cheap china tool - figures) - but it came out luckily. Then just using a 3/8 Craftsman ratchet with a pipe got it loose with a prayer. I live in Cali so the VTM4 doesn't get used much except trips to the mtns in the winter 2-3 times a year. The minder never called for it so I didn't bother but at 30k mi I figured I better do it with the oil change. The fluid looked like new and I never had any issues with it so I cant see doing it every 15K mi in my case? I think the front diff fluid should be changed? Anyone care to add thoughts to that? Now the cabin filter
06 Pilot Ex 4WD (RIP Old Friend) 08 Acura MDX New Family Truckster - Wifes 2011 Tacoma 4x4 Double Cab TRD Off-Road - Mine Last edited by CNJ; 05-12-2010 at 05:40 PM. |
