Torque Specs and diff change - Honda Pilot - Honda Pilot Forums
Old 04-30-2010, 10:58 AM   #1 (permalink)
Default Torque Specs and diff change
Can anyone tell me the procedure for changing the rear differential fluid in an 05 Pilot and weather I should do it cool or at operating temperature?
I was also hoping someone could tell me the specified torque for:
Rear Brake pad bolts (as needed to change pads)
Transmission drain plug
Differential drain plug
Any help would be greatly appreciated.
JDESIGNS is offline   Reply With Quote
Old 04-30-2010, 11:44 AM   #2 (permalink)
cwa107's Avatar
Here you go:
DIY VTM-4 (differential) Fluid change with pictures
You will want to pick up a jug of VTM4 fluid from your local Honda dealer as it is proprietary.
Old 05-01-2010, 01:00 AM   #3 (permalink)
ATF-Z1 08200-9001
18mm ATF Drain Plug Washer 90471-PX4-000 (36 ft/lbs)
24mm ATF Fill Washer 90441-PK4-000 (33 ft/lbs)
VTM-4 Fluid 08200-9003
18mm VTM-4 Drain Plug Washer 90471-PX4-000 (35 ft/lbs)
20mm VTM-4 Fill Washer 94109-20000 (35 ft/lbs)
20mm Transfer Case Drain/Fill Washer 94109-20000 (33 ft/lbs)
