Service manual owners: Torque setting for third row shoulder harness bolt? - Honda Pilot - Honda Pilot Forums
Old 03-25-2010, 10:48 PM   #1 (permalink)
Default Service manual owners: Torque setting for third row shoulder harness bolt?
Hi, I'm hoping someone with a service manual can tell me what the torque value should be for the bolt holding the shoulder harness in the 3rd row. It's right in the middle of the rear pillar. See pic...
Thanks!
stubble is offline   Reply With Quote
Old 03-26-2010, 01:17 AM   #2 (permalink)
Default Re: Service manual owners: Torque setting for third row shoulder harness bolt?
Thanks!
Well, if I'm reading my service manual correctly it's 3.3 kgf-m or 24 lbf-ft which I assume is 24 foot pounds.
If you're near the Campbell, CA area you can double check in my manual if you'd like.
Good luck!
Larry.
DiskStroyer: http://www.diskstroyer.com
larrys is offline   Reply With Quote
Old 03-26-2010, 11:31 AM   #3 (permalink)
Default Re: Re: Service manual owners: Torque setting for third row shoulder harness bolt?
Good luck!
Larry.
Thanks Larry, that sounds reasonable!
Sebastian
