Replacing headlights question - Honda Pilot - Honda Pilot Forums
Old 02-20-2010, 02:47 PM   #1 (permalink)
Default Replacing headlights question
I am trying to change out the bulbs on an 06 Honda Pilot and the plugs won't come off the bulb. Any ideas on how to loosen that up?
crownroyal is offline   Reply With Quote
Old 02-20-2010, 05:42 PM   #2 (permalink)
RSQ Pilot's Avatar
Garage
Default Re: Replacing headlights question
Tried a couple of drops of WD40 in the slots and after a few minutes some wiggling?
use some dielectric bulb grease to prevent future problems.
2010 Honda CR-V EX-L 4WD Taffeta White...OEM cargo tray, mudguards and WeathertTech floor liners; Blue Ox dinghy setup.
Old 02-20-2010, 06:27 PM   #3 (permalink)
Remember its meant to be a PULL not a wiggle, so be careful not to split the plug if you do wiggle.
Old 02-21-2010, 12:21 AM   #4 (permalink)
Thanks for the replies.
I couldn't get it out and didn't have any WD40. I was worried that I was going to crack the plastic plug because I was really putting some pressure to get that thing off. Eventually I contacted my local Honda dealership and they said just bring it in and they would take care of it for free. I think they did put some sort of lube to prevent it in the future.
