I am planning on changing my front brakepads this weekend and have read that the towhook is the central jacking point in order to set jack stands under the pinch welds. Is there a device made for using with a floorjack that cradles the hook, or is there a household item that'll work safely? Thanks for any help.
TJ |
#2 (permalink) | |
The problem you may run into is having enough vertical lift to be able to get the wheels off the ground. The hook is pretty high up the chassis and with the suspension extension it takes a lot of vertical lift by the jack to make it. My HF jack wasn't even close, so I ended up jacking on each side at a frame point near the suspension attachments. There is a pad-like area there which is part of unibody frame and I'm reasonably sure it can take the stress of jacking a corner. - Mark |
Jon |
#9 (permalink) | |
I read somewhere (here I think) that a guy liked to use a hard rubber hockey puck between his jack cradle and the vehicle lifting point. Unlike wood, the rubber is much, much less likely to split under the load. I actually tried the hockey puck myself and it seems to do the job pretty well. I've also jacked the Pilot up from the front tow hook without the puck and it was fine as well. I have a jack just like the one pictured in this thread; it provides an ample amount of lifting height.
I understand the tow hook is the proper point, just a little nervous since doing it for the first time and want to do it safely. I do plan on simply jacking high enough to get jack stands under the pinch welds on each side, lowering onto the stands, then leaving the jack engaged as well. The jack I bought for the job came from Advanced Auto Parts and is a Torin 2.5-ton Quick Lift Trolley Jack. I've already tried it to make sure it will jack high enough to get the stands in place.....it will. Thanks everyone for the help and advice.
