Need central jacking points for 2004 - Honda Pilot - Honda Pilot Forums
Old 02-05-2010, 01:47 AM   #1 (permalink)
doctorj's Avatar
Default Need central jacking points for 2004
I want to start doing my own tire rotations, but don't know where the front and rear jack locations are. My plan was to jack from these points, and put 4 stands at the pinch weld locations. Any help would be greatly appreciated.
2004 Pilot EXL-RES, SBP (her car)
2001 Accord LX, Gold (my car)
doctorj is offline   Reply With Quote
Old 02-05-2010, 06:42 AM   #2 (permalink)
The jack points are described in the owners manual. I've only ever had to change a front tire and that was the sill. Rear may be the same
Old 02-05-2010, 10:06 AM   #3 (permalink)
doctorj's Avatar
I think you misunderstood my question. The jack points in the manual are the locations I said I would put the jack stands AFTER I raised it with the jack. There is a point near the front where you can raise the whole front end at once and there is one in the back where you can raise the back end at once. I was going to jack the car up using the locations in the owner's manual, but if I lift from this point, where would I put the stand so I can remove the jack and go to a different location?
Old 02-05-2010, 10:37 AM   #4 (permalink)
onu2002's Avatar
For the back there's a flange near the rear diff that you can use if you have a floor jack that's long enough. I tried using the tow hitch, but that didn't get the tires off the ground.
I don't remember what I used in the front. There might be a frame member that you can use.
Tom
2003 Honda Pilot EX
2004 Honda S2000
2006 Hyundai Sonata GLS
Old 02-05-2010, 10:38 AM   #5 (permalink)
onu2002's Avatar
Here ya go:
Jacking Points
...from a search for "jacking points."
Tom
2003 Honda Pilot EX
2004 Honda S2000
Old 02-05-2010, 09:52 PM   #6 (permalink)
doctorj's Avatar
Thanks for the help.
