Superior Honda Tech
hey everyone. sorry i dont get on much but I re-enlisted and havnt had a lot of time for anyone.
DIY. what are some ideas or repair procedures you would like to to see or know about? also what do you guys think of making videos...like you tube and linking them here? I will do my best to make the DIYs as shadetree mechanic as possible. best OBD2 code reader ever..... http://www.mactools.com/product/tabi...5793-et80.aspx simple easy cheap and you can plug it into your comp and update it.
ASE master certified Honda Technician Former USMC Sgt. 10 years Army National Guard Sgt. 2 years |
#2 (permalink) | |
Really nice to see you posting on here again.
A timing belt DIY would be great. I know there are a few short writeups scattered here and there on the site but an official timing belt thread with pictures would be great. Some of the more simple stuff would also be nice, like changing coolant or changing serpentine belts, as someone like you would have some tips that may make the job easier. Videos are a good idea, but I think clear pictures are just as effective.
Feedback Score: 1 reviews
A solid write-up on the timing belt replacement is a great idea. Thanks in advance if this is something you can do for us. Jestmaty-
Maybe I'll tackle it myself second time around.
Quick question regarding possible damage to 4-cyl. Honda engine:
(Note: I also have an '09 Pilot and apologize in advance for posting this question about my Accord). I recently discovered that my '00 Accord (with 140K miles) had been overfilled with oil by two quarts and driven about 200 miles in that condition. It's been drained down to the correct level, but I'm wondering what sort of damage could have been done to the oil seals, etc? Is there anything to do at tnis point, other than wait and see what happens next? I understand the excess oil could have leaked - and damaged - the timing belt, which was changed two years ago. Fortunately, the car still runs OK, but I wonder for how long. |
If the oil spit out, it will do no more damage than any other case of spilled oil. (Belts and such. I would not be overly concerned of the timing belt since it is toothed.
If the engine ran normally other then spitting oil, then there is nothing to worry about.
Superior Honda Tech
you will be fine. the honda engine is a lot better design then the old chevy V8's with brass freeze plugs. correct the level and drive away. too much oil will affect performance tho. too much oil pressure. but honda engines are engineered so well that the bearings never wear out. dont worry about it.
Superior Honda Tech
Any owners in the charlotte area? i will do work on their vehicle at a major discounted price to help in the DIY. if I did it at work i might get into trouble plus it will be hard to show you how to do it if im using a lift and air tools.
Superior Honda Tech
so far i have on my list:
BY request timing belt, coolant flush, maybe a revision of some older DIY's My ideas: 90k, 105k servic,e transfere case oil change, egr port clean, blower motor, transistor replacement, drive belts, power steering pump for those daring enough: valve adjustment, front and side engine mounts
#13 (permalink) | |
#14 (permalink) | |
