Liftgate strut replacement "how to" ? - Honda Pilot - Honda Pilot Forums
Old 01-10-2010, 11:29 AM   #1 (permalink)
Default Liftgate strut replacement "how to" ?
A few searches didn't turn up a thread on how this is done...unless I'm just using the wrong terms.
I've seen it referred to as a "5 min job," so I'm assuming there isn't much to it, but wanted to make sure how it was done.
Bean is offline   Reply With Quote
Old 01-10-2010, 12:18 PM   #2 (permalink)
onu2002's Avatar
I've not seen a how-to, but I would probably use a 2x4 to prop the tailgate up and do one strut at a time.
If you don't have a Hayne's manual you might want to pick one up at an auto parts store.
Tom
2003 Honda Pilot EX
2004 Honda S2000
2006 Hyundai Sonata GLS
Old 01-10-2010, 12:42 PM   #3 (permalink)
samc's Avatar
I think you just pull out the tabs on the strut ends and that's how you take it off. If you look at the end where it attaches you will see a tiny tab with an indent where you can use a screw driver to do a lift. Then pull the strut away.
And yeah someone should be holding the rear up unless you want to be knocked out cold.
