Transmission Drain Plug Stripped - Honda Pilot - Honda Pilot Forums
Old 12-29-2009, 07:21 PM   #1 (permalink)
I'm thinking they used a longer plug that engaged the threads deeper.
I can't imagine stripping that hole, unless it was started crooked and driven on with a ratchet or air wrench. I mean if you hand threaded it up snug and then just tightened it with a 3/8 drive ratchet, it would be hard to strip as most aren't long enough to apply that much pressure.
More likely someone tried to remove it with a 3/8 impact or put it back in with one and stripped it.
Hey, after the Dealer replaced the tranny in 2001 Accord under the Honda trans warranty deal, I found 12 bolts missing, including the ones holding the battery tray, numerous hose brackets, etc. Thankfully, most of them were rolling around in the cowl area around the wipers
I agree, it looks pretty good. the only thing is the factory plug had a magnet on the end of it I believe, no idea what this thing has.
JW
'04 Sage EX, Husky liners Front and 2nd, Rear OEM Cargo Tray, Cargo Cover, Mud Flaps, Wheel Locks, OEM Towing Package, Full Size Spare, WWong's Foam Pad Kit, Cloudrider Spectare Mesh Grill, Thule Rack, more to come!
Sage_EX is offline   Reply With Quote
Old 12-30-2009, 01:58 AM   #2 (permalink)
xGS
xGS's Avatar
Dealer probably made the repair using a kit such as these:
[http://www.timesert.com/html/drainplug.html].
If needed, new magnetic drain plugs can be had here:
[http://www.magneticdrainplugs.com]
Old 12-30-2009, 09:44 AM   #3 (permalink)
Those are great sources, xGS. Thanks.
normkol is offline   Reply With Quote
Old 12-30-2009, 05:42 PM   #4 (permalink)
That is a great resource!
JW
