I need some recommendation on replacement parts for front brake disk and pads for my 2006 EX-L 4WD. OEM parts are not too expensive, but there are a lot of aftermarket parts that are available for less. Please let me know the brand, model, and the place where I can get them. Thanks in advance.
2006 Honda Pilot EX-L 4WD -Pioneer AVIC-D2 Navigatioin with Rear View Camera -Westin Running Boards 2003 Honda CBR954RR Black/GunMetal 2006 Nissan Altima SE |
Check out Rockauto.com for non-OEM. Raybestos Professional, Beck Arnley, Wagner.
I bought Raybestos Pro's for a Highlander last year--great quality and machining. Perfect fit.
Feedback Score: 1 reviews
Can't tell if you're in the US or not, but down in Texas, we have Autozone as a source for replacement parts.
I put on a set of Duralast Gold pads and have been VERY pleased since the job. Maybe 12,000 miles ago... They are ceramic and are a very low brake dusting material. Like them so much that I took off the brakes from my wife's Pontiac Vibe and put the same Duralast Gold on hers too. That is after I did the first brake pad replacement about 15,000 miles ago and have a ton of pad left on the replacement pads. Her car needed brakes at about 36k and I put Autozone semi-metallic on it and they were awful. They were grabby and absolutely COATED her aluminum wheels with brake dust. So... even though they still had a long way to go, I spent the $ and got the Duralast Gold and did a 2nd brake job. If I recall, my '04 Pilot pads cost approx. $35 for the front set and $33 for the rear. FWIW..
Is there a way you can check the brake pads without taking the wheels off?
thanks
formerly 2003 EXL Pilot 16k Miles RES Now 2005 EXL Pilot 71k Miles |
- Mark |
#8 (permalink) | ||
If you take the wheel off, there's a small window/opening on top of the caliper where you can see the brake pad thickness. If you undo the lower caliper bolt and rotate the caliper up, you can pull the pads out for an even better view. Check out the DIY Brake Thread (stickied) in the maintenance section for more info.
#9 (permalink) | |
my local dealer has occasional sales on service. Last couple weeks has been brakes for $99 per axle. I had it done yesterday front and back, price was accurate.
It figures I missed the $400 timing belt, water pump deal, after I paid $800. Can't win them all...Dealer is Hamilton Honda......I don't work there, just want to pass on the info... Cheers!
'05 w/Navi - Traded in at 136K for.. '08 EX |
