Timing Belt Question... - Honda Pilot - Honda Pilot Forums
Old 08-15-2009, 09:39 AM   #1 (permalink)
Default Timing Belt Question...
Service manual shows to use a battery securing bolt to hold the timing belt adjuster when removing the timing belt...
Does this matter if I am replacing the adjuster anyway?
Closer_2001 is offline   Reply With Quote
Old 09-10-2009, 12:19 AM   #2 (permalink)
No it does not matter if you are replacing the tensioner. Remeber to replace the bearing as well along with the w/p while you are there. The hardest part of this job is breaking loose the pully bolt!
mrkatt is offline   Reply With Quote
Old 09-10-2009, 09:45 AM   #3 (permalink)
Thanks for the reply...job went off without a hitch! Replaced WP, everything actually looked quite good.
