repost -- maintenance question--replacing engine air filter - Honda Pilot - Honda Pilot Forums
Old 08-14-2009, 04:10 PM   #1 (permalink)
Default repost -- maintenance question--replacing engine air filter
Resubmitting question under correct category.
Need advice about replacing engine filter for my 2006 Pilot. I have the 4 bolts removed and can lift-up the air cleaner cover, but not enough to access/remove the air filter. The air-flow-tube connected between the air cleaner cover and engine block is limiting me from lifting the cover further to access/remove the filter. Do I need to remove the air-flow-tube clamp or spring to be able to lift the cover and get to the filter? Any advice is appreciated. Thanks.
spikeit1 is offline   Reply With Quote
Old 08-14-2009, 09:09 PM   #2 (permalink)
bigdadi's Avatar
I have the 08 Pilot. After loosen all 4 screws I managed to lift the cover high enough that I can lift the old filter up and slided it out side way. Install the new one in the same manner, slide it in then make it sit in.
BigD
Old 08-18-2009, 08:09 PM   #3 (permalink)
Thanks BigD. I'll give it a try your way.
