Pilot Maintenance Minder - Nervous - Honda Pilot - Honda Pilot Forums
Old 07-21-2009, 07:08 PM   #1 (permalink)
Default Pilot Maintenance Minder - Nervous
Hi gang,
My '08 Pilot has around 19K on the clock, and the "B 1" maintenance minder just came on. I used to manage an oil change shop as a kid, and have always abided by the "3K miles" rule.
I know lubricants and engine design is far improved, but if I recall, my last maintenance minder was at around 11K miles. Honda keeps telling me to chill out, and follow the maintanance minder, as that's what is used for warranty purposes, but I'm having a hard time with this.
Do you simply follow the maintanance minder?
rc620 is offline   Reply With Quote
Old 07-21-2009, 07:23 PM   #2 (permalink)
samc's Avatar
yes if you were really worried you could have changed the oil. I mean you waited 8k?
My last went 7k and when the oil came out it looked the same as when I changed the oil on my old VW with 5k changes. Just make sure to use synthetic which you already know from experience.
And I forget what 1 means but perhaps tire rotation? Ofcourse only do that one if you see more wear on the fronts vs rear.
Old 07-21-2009, 07:37 PM   #3 (permalink)
Originally posted by samc
. . Just make sure to use synthetic . . .
Why?
Old 07-21-2009, 08:25 PM   #4 (permalink)
samc's Avatar
N_Jay why ask a question where you already know the answer. Let's not start another comparison thread.
Old 07-21-2009, 09:09 PM   #5 (permalink)
I don't kn ow "Why". I know it is a commonly held OPINION.
Old 07-22-2009, 12:50 AM   #6 (permalink)
It's not opinion that synthetic is a better motor oil - any number of tests can be run that clearly show synthetic is a superior lubricant.
Whether the extra protection it provides is worth the extra money or is "needed" is certainly open to debate. My recommendations: For a car on a 3-year lease or that is traded when the tires wear out, use conventional. For a car that is going to be kept for 100K+ miles, I think synthetic is worth the extra expense.
Back to the original question, Honda's maintenance minder recommendations seem very conservative these days - when many cars are recommending 15K+ intervals between oil changes, most Honda MM systems seem to be calling for 5K-8K oil changes. I'd just follow it.
Old 07-22-2009, 07:02 AM   #7 (permalink)
Evidence?
Or are you just perpetuating a "myth" (using your language from another oil post)?
Old 07-22-2009, 01:29 PM   #8 (permalink)
Evidence?
It was a recommendation based on my experience which the OP can take or leave.
My rationale is pretty simple: for a car that is going to be traded or sold in a few years, there is no evidence whatsoever that indicates conventional oil won't perform adequately and since the car is under warranty, why not save money and simply meet the letter of the warranty requirements?
But for a car that is going to be kept a long time and driven well outside the warranty, the small increment cost of a demonstrably better oil is probably worth it, especially if you live in a very hot or very cold climate or tow. It also provides extra headroom if you're on a trip and want to extend an oil change. These advantages seem worth the extra cost.
Old 07-22-2009, 01:52 PM   #9 (permalink)
What experience?
Very true, except. . . .
For a car that is NOT going to be traded or sold in a few years, is there any evidence whatsoever that indicates conventional oil won't perform adequately?
Based on?
Looking for more evidence?
Do you have any evidence that a few "extended" intervals cost the average "long term owner" anything?
They might "seem" that way to you, but without evidence, I might seems more like myths to me.
Old 07-22-2009, 02:09 PM   #10 (permalink)
We've both made our points. I leave it as an exercise to the reader on who has provided more useful info on this topic.
Old 07-22-2009, 02:44 PM   #11 (permalink)
OK, but to counter your overwhelming evidence, I would just like to state, that in almost every one of these discussions, I have asked if ANYONE has EVER seen an oil related failure of a properly (even if minimally) maintained Honda engine.
So far no one has presented any indication that there is any significant value difference between conventional and synthetic oils.
I leave it open for others to present their evidence (knowing that the lack of information is not "proof" and is only an indicator.)
Old 07-22-2009, 05:58 PM   #12 (permalink)
samc's Avatar
Ok I'll rephrase my response. Obviously if you were leasing the car why would you care about the extra protection that synthetic oils will provide for you. That falls in line with using octane 93 gas on a loaner, who does that?
but if you plan to keep you car passed 100, 200k miles then get into the habbit of using synthetic. And as far as economics are concerned I've seen a 5-gallon bottle of sythetic sell for $19.99 (very very good sale) so look around and if you see the prices I suggest you stock up.
Old 07-22-2009, 07:36 PM   #13 (permalink)
Is including 6 quote sections a new record for you N_Jay?
Old 07-22-2009, 08:33 PM   #14 (permalink)
EXCEPT that no one has provided a single stich of EVIDENCE there is any VALUE to that "extra protection"
I would guess people TWICE as foolish as those that put 93 gas in any car that does not require it.
(Unless you believe the MYTH that higher octane is BETTER gas?)
Why?
What evidence?
I have 145,000 on my pilot and 90,000 on my CRV. typical maintenance, conventional oil, no oil usage or other indication that either would be doing any better with synthetic.
ALSO:
165,000 miles on the Range Rover, no issues when sold,
108,000 miles on the Civic, No issues when sold and for many years after
140,000+ miles (Broken odometer) on the 924, and no issues when sold
]And as far as economics are concerned I've seen a 5-gallon bottle of sythetic sell for $19.99 (very very good sale) so look around and if you see the prices I suggest you stock up.
The same savings process could apply to conventional, so it is not relevant.
Old 07-22-2009, 08:34 PM   #15 (permalink)
Maybe in this forum, but I doubt it.
