headlights - Honda Pilot - Honda Pilot Forums
Old 07-17-2009, 10:22 AM   #1 (permalink)
Default headlights
We have a 2005 pilot. How do you adjust the headlights to the proper angle?
thundergas is offline   Reply With Quote
Old 07-17-2009, 10:30 AM   #2 (permalink)
On the LIE someplace...
Ty Shoes's Avatar
I thought they were fixed position...
2004 Blue LX - no frills beast with Weathertech Vent Visors
135,000+ miles!
Ty Shoes is offline   Reply With Quote
Old 07-17-2009, 11:19 AM   #3 (permalink)
Normal procedure is to put the vehicle 25ft away from a wall with the lights shining on it. Then you have to compare the beams pattern on the wall.
Driver side should be lower than passenger side.
There is a place on each headlight, usually at the top inside the engine comparment where you can put a large phillips in and turn to raise or lower the assembly.
2009 DCP Touring, Navi & RES
2008 Ducati 1098 R.I.P.
Old 07-17-2009, 11:21 AM   #4 (permalink)
Default Re: headlights
I think it is in the owners manual.
There were a few threads a while back you might be able to find with a search.
Don't set them too high because any weight in the back will put them into peoples eyes.
Old 07-17-2009, 08:08 PM   #5 (permalink)
samc's Avatar
Are the adjusters on our headlights made of plastic? If so remember to shoot a wd-40 or silicone spray before hand.
Old 07-18-2009, 11:21 PM   #6 (permalink)
aenergy's Avatar
I just adjusted mine a few weeks ago.
A socket will do the job.(sorry,don't remember what size was it.)
Passenger side is a piece of cake,no biggie.
But for driver's side,u may need to remove the electrical connector & rubber weather seal
to gain a little more room if u need to adjust
the light Up or down.
aenergy is offline   Reply With Quote
Old 07-19-2009, 12:06 AM   #7 (permalink)
thanks for the great replies....appreciate the information...
