MM B16 code, 66k miles. - Honda Pilot - Honda Pilot Forums
Old 06-14-2009, 12:27 PM   #1 (permalink)
Default MM B16 code, 66k miles.
This spring we got the Mrs. an '06 pilot - the 4wd one. We bough it right at 60k miles. When we got it the oil had been just changed by the dealer prior to it's sale, and the week we got it I replaced the atf, vtm-4, and pollen filter (which had never been replaced before) basically did a 45k and a 60k combined. (by the earlier maintenance standards.)
Now, at 66k miles the MM light is coming on with the code B16, oil change and vtm-4 fluid.
Do these vehicles have an actual fluid life sensor, or is it just a maintenance time / mileage calculator? I seriously doubt the fluid needs to be changed again after 6k miles.
I just changed the oil and I figured out how to reset the light, but if it is a time / mileage / load calculated value, I guess it means my vtm-4 fluid reminder isn't going to be accurate.... I'm fine with replacing it according to the earlier service interval. I'm a believer in earlier and not completely necessary maintenance vs. later maintenance.
NickG is offline   Reply With Quote
Old 06-14-2009, 12:47 PM   #2 (permalink)
samc's Avatar
Site says
engine oil, rotate tires and Vtm fluid.
If you have replaced it already I wouldn't worry about it. And yes the computer uses a calculation and that it doesn't magically know that your vtm fluid actually needs to be replaced.
________
Replace engine oil1 and oil filter
Inspect front and rear brakes
Check parking brake adjustment
Inspect tie rod ends, steering gear box, and boots
Inspect suspension components
Inspect driveshaft boots
Inspect brake hoses and lines (including ABS)
Inspect all fluid levels and condition of fluids
Inspect exhaust system#
Inspect fuel lines and connections#
Old 06-14-2009, 01:29 PM   #3 (permalink)
Default Re: MM B16 code, 66k miles.
Originally posted by NickG
. . Do these vehicles have an actual fluid life sensor, or is it just a maintenance time / mileage calculator? I seriously doubt the fluid needs to be changed again after 6k miles. . . . .
It is a "Smart" time/mileage calculator.
It takes into account number of starts, time at temp, and a few other wear indicating metrics from the ecu.
