Time to change brake pads for my Pilot at ~60k. Thinking to change rotors as well since it has moderate pulsation at stopping. My question is, should I change the front or rear rotors for the pulsation issue. Any body have to change rear rotor for the problem and how you diagnose it? Thanks in advance!
Min
2005 Pilot EX, Sage Brush with Runing Board |
Other than "feel", or actually taking rotors off and doing a detailed inspection, I don't know of any way to tell which rotor is warped.
But, it's typically the fronts, so if I were you, I'd probably change the front rotors, just do pads (if needed) in the back, and hope for the best. - Mark |
![]() Join Date: Feb 2004
70k miles when I changed my brakes. Changed pads all around, and rotors in front only. The front rotors were the culprit for the pulsation. May be the same for you.
Remember, rear pads will wear first, and they led my fronts by about 20%. Hope this helps.
2004 Sandstone EX-L OEM Splash Guards, OEM Cargo Tray, A whole bunch of WWong pads (I've been Wonged!), Lund Interceptor Bug Deflector (Smoke color), Stylin'!!! with the stiles_s Rear MDX brace kit. |
Rears wear first? Was this a typo? I've already replaced front pads on my '03 at 60k, but the rears were still 50% or better.
front rotor warp is felt in the steering wheel, rear rotors through the seat. Rears rarely warp as they don't do as much, don't go through same temp extremes.
2006 Pilot EX-LN 4WD | Taffeta White | "Amelia" OEM accessories: chrome side steps, crossbars, cargo tray, cargo cover, wheel locks, rear splash guards, door edge guards, full-size spare Aftermarket accessories: Yakima Big Powderhound, LED license plate and door bulbs, Infinity 6012i speakers, 4300k HID, 35% tint, Nokya yellow fogs + yellow Lamin-X |
very interesting. maybe i should get my pads checked by another mechanic and see if i get a different result.
Changed the brakes over the weekend. I finally changed all four rotors since NE harsh whether took a toll on the metal parts. The rear rotor's outer edges were all raised and the new pads won't fit. The front rotor was completely stuck to the hub. Took me whole day to take them off.
NAPA premium rotors (front and rear) and Honda OEM pads were installed. Since I am reaching 60k and the car is on stand, I changed all fluids and all filters as well. So far everything works good. I am still gentle on brake for now. Will give it a hard test after 100 miles or so. BTW, the rears do worn faster then fronts. I have about 2mm left at rears and double that left at fronts when took them off.
I had the same brake pulsation problem.
I simply had the front two rotors resurfaced at the local machine shop (~$40) and now the brakes are like new. (Rear rotors contribute little to this issue or hard braking for that matter) |
