Doing rear brake job on my 2005 Pilot this weekend. Does anyone know the torque settings for the rear calipers? Are they the same as the fronts? I am having trouble finding a DIY write up for the rears but just really need those torque settings!
Thanks all... Mike |
Mosquito Mechanic
howdy,
I too was looking for torque specs. have a look at the General> maintenance> DIY brake job. the 4th page has torque values. The caliper brackets on the back are very similar to the ones on the front. I was given some values: cal brkt 79.6 ft lbs cal flange blt 27ft lbs. I was too late in changing the front pads. I'm presuming that one end of the brake pads was dragging because of uneven wear. Almost like a wedge shape. The warning bar had just begun to touch and sound it's warning of low pads when the metal at the other end of the pad started a groove in the disc. Fortunately, it wasn't too deep to have the disc turned.The hardest part will be getting the screw off that holds the disc to the hub!! I destroyed all 4 screws. Perhaps an impact screw driver may have helped. Best of luck, GFB
+++===========+++ 2003 Pilot EXL-RES 2011 Fit Sport ![]() 2004 2500 Ram Diesel Yaesu FT-8800r ---------------------------- Going Where everyone has gone before... |
No, the backs cal brkt are different from front. I remember it's 41 ft.bl. I will check with my shop manual and post back. The flanges' torque is same at 27 ft.bl.
Min
2005 Pilot EX, Sage Brush with Runing Board |
My feeble brain says they are the same torque specification, but I am traveling and can not check the manual.
Checked shop manual. Front 79.6 ft.bl and rear 41 ft.bl for the Cal brkt. Both flanges at 27 ft.bl.
