105k maintenance with parts list - Honda Pilot - Honda Pilot Forums
Old 03-15-2009, 11:29 PM   #1 (permalink)
scuba steve's Avatar
Default 105k maintenance with parts list
12341-P8A-A00 GASKET, HEAD COVER 2 $4.53 $9.06
12342-P8A-A01 SEAL, SPARK PLUG TUBE 6 $1.77 $10.62
14400-P8A-A02 BELT, TIMING (197YU26) 1 $28.02 $28.02
91213-P8A-A01 OIL SEAL (39X53X8) 2 $4.14 $8.28
91212-P8A-A01 OIL SEAL (41X56X8) 1 $6.31 $6.31
19200-P8A-A02 WATER PUMP 1 $90.97 $90.97
38920-P8F-A02 BELT, COMPRESSOR (MITSUBOSHI) 1 $18.31 $18.31
56992-P8A-A01 BELT, POWER STEERING PUMP (MITSUBOSHI) 1 $10.73 $10.73
14520-P8E-A01 ADJUSTER, AUTOMATIC 1 $70.09 $70.09
14510-PGE-A01 ADJUSTER, TIMING BELT 1 $54.67 $54.67
14550-PGE-A01 IDLER, TIMING BELT 1 $30.32 $30.32
19301-P8E-A10 THERMOSTAT ASSY. (NIPPON THERMOSTAT) 1 $23.22 $23.22
19501-PGK-A00 HOSE, WATER (UPPER) 1 $10.90 $10.90
19502-PGK-A00 HOSE, WATER (LOWER) 1 $10.90 $10.90
Subtotal $382.40
cranktool from amazon $25
i still have to buy spark plugs and coolant.
i bought the parts from majestic honda. i built the same list on napaonline. majestic was cheaper and i know that i'm dealing with OEM honda stuff. it's my wife's vehicle, so i like to make it bulletproof.
i am doing the timing belt job, valve clearance, and coolant flush.
i thought this list with the part nubers would be helpful to someone else.
'03 pilot
'92 miata
'95 ///m3
scuba steve is offline   Reply With Quote
Old 03-16-2009, 05:08 AM   #2 (permalink)
Might be useful to add the year of your Pilot due to design changes that took place
Old 03-17-2009, 12:08 AM   #3 (permalink)
2003 as listed
'03 pilot
'92 miata
'95 ///m3
Old 03-18-2009, 09:16 AM   #4 (permalink)
PSH
i thought this list with the part numbers would be helpful to someone else.
Thanks!
Should the intake manifold cover gaskets & spacer gaskets be replaced, too? (3 gaskets total)
04 Pilot EX-L
01 B5.5 Passat 1.8T Variant
PSH is offline   Reply With Quote
Old 03-18-2009, 04:35 PM   #5 (permalink)
grumpy's Avatar
Thanks for posting the parts list. If I can't make a deal on an 09 soon (I've been trying for three months; trade in amount is the problem) I'll keep my 04 Pilot for a couple of more years and will need to do the 105 k maintenance; currently at 90k. I have zero mechanical skill so will have the work done at a Honda dealer.
grumpy is offline   Reply With Quote
Old 03-31-2009, 12:36 AM   #6 (permalink)
Originally posted by PSH
Thanks!
IM shouldn't have to be removed AFAIK.
'03 pilot
'92 miata
'95 ///m3
Old 04-03-2009, 03:33 PM   #7 (permalink)
nighthawkpilot3's Avatar
Default 105K Service
Hey guys. Did this back in the winter. Actually did all but the valves and belt at 105K and then finshed - at over 142K I am sad to say. Belt looked great. Tensioner had been replaced on recall back some time ago. Water pump looked great too. All the exhaust valves needed adjustment but the intakes were ok (exhaust hotter of course). U do need to take off the intake and replace the gaskets (it has a spacer and uses 2 of the same part #). Also need the upper cover gasket. Only about $40 for all plus s and h from Majestic. Belts can be obtained at any parts store. Need to replace all at that time too. You will need the special tool referred to in the manual, as you cannot get the crank bolt out without it. Mine was in there such that I had to wedge the tool and ratchet holding the it against the frame and crank over engine (pull the ignition fuse 1st!) while I held the other with my foot to break loose. Be sure you set them correctly - clockwise and counterclockwise so that the engine turning does it. You dont need a press to reset the adjustor either - you can find a solid part of the frame and use a jack to press it back down. You must have a really solid pin for it too. Dont even attempt this job if you dont have the service manual. And it takes a while - esp if you are careful by nature and not familiar with the procedure. Post back any questions and I will answer.
nighthawkpilot3 is offline   Reply With Quote
