Front differential fluid change? - Honda Pilot - Honda Pilot Forums
Old 01-02-2009, 12:20 PM   #1 (permalink)
Default Front differential fluid change?
I've just completed the rear differential fluid change with VTM-4, the transfer case fluid change with Amsoil Severe Gear oil, transmission drain and refill with Honda Z-1 and engine oil change with Pennzoil Platinum.
Since this vehicle is AWD, is there a front differential fluid we need to change?
I always see threads about the rear differential fluid change but never about the front.
The vehicle in question is an '06 Pilot AWD EX.
Spartus is offline   Reply With Quote
Old 01-02-2009, 02:11 PM   #2 (permalink)
jestmaty's Avatar
Feedback Score: 1 reviews
A transmission fluid change is the recommended 'front differential' service item.
The transaxle houses the gears that drive the front wheels, and Honda ATF is the recommended fluid.
Do a search on transmission fluid change and you'll get all you need to do it yourself.
2004 EXL-RES Sage Brush Pearl
2005 Bayliner 175XT Bowrider
Old 01-02-2009, 02:41 PM   #3 (permalink)
So the front differential does not have a separate drain from the transmission? So the Pilot setup of the differential is similar to many front wheel drive vehicles where the differential shares the fluid with the transmission?
Basically, the drain and refill of the transmission also exchanges the differential fluid at the same time since they share the same housing?
Old 01-02-2009, 07:12 PM   #4 (permalink)
If you are referring to the "Transfer Assembly", then I can attest that the 2007 has a separate unit from the transmission, lubricated by a small quantity of 80W-90 gear lubricant, and is an easy fluid change.
Sylvatica is offline   Reply With Quote
Old 01-02-2009, 07:16 PM   #5 (permalink)
jestmaty's Avatar
You got it!! Correct.
I just crested 60k a couple of days ago, and have done ALL my maintanence myself. The tranny fluid change takes care of the entire front driveline.
Old 01-03-2009, 09:33 AM   #6 (permalink)
dj5
That is not correct for 2006 and newer Pilots. Sylvatica is correct, the front differential does have a separate drain from the transmission. I recently changed the fluid in my "06 with Vavoline synthethic 75w-90 gear lubricant.
Read more in the following link.
Quickest Fluid Change
Old 01-03-2009, 10:03 AM   #7 (permalink)
jestmaty's Avatar
Oops, I stand corrected!
I was still operating in New Year's Eve mode ( ie "hungover" ) when I responded.
Old 01-03-2009, 05:04 PM   #8 (permalink)
Are you referring to the transfer case? If so, I changed the fluid in that to Amsoil Severe gear 75w-90.
My question is in reference to the front differential.
Old 01-03-2009, 09:58 PM   #9 (permalink)
Medic721's Avatar
yup about 1/2 qt of mobil 1 gear lube. in 06 and newer piots.
-Mike.
Old 01-03-2009, 11:51 PM   #10 (permalink)
-Mike.
Yes, the gear lube I am aware of for the transfer case.
No one has answered my question about the FRONT DIFFERENTIAL.
Old 01-04-2009, 02:33 AM   #11 (permalink)
jestmaty's Avatar
I already found my goof a few posts ago, but, I can pretty much say with 'utmost confidence' that we don't have front differentials on our Pilots.
Yes, it appears that 06 and newer Pilots do have a separate transfer case that are serviceable by a fluid change. I've spent a lot of time under my Pilot and I've never seen a diff.
My 04 only calls for a tranny fluid change at certain times. It seems that 06 and newer have another drain and fill point, the transfer case ( which you have already taken care of )
After that, the rear 'diff', ie VTM4, has a very easy drain/fill process to keep the fluid clean. There is no other draining needed on a Pilot.
Old 01-04-2009, 11:07 AM   #12 (permalink)
Medic721's Avatar
jestmaty is correct no seperate front differential, but a seperate section of the transaxle. (transmission/axle). Gear lube for the one section and Honda ATF for the transmission.
-Mike.
Old 01-08-2009, 02:31 PM   #13 (permalink)
Correct.
The transverse mounted, front wheel drive configuration utilizes the transmission (lubricated with the same Z-1 ATF as the transmission) as the integral "front differential".
Power is simultaneously taken off the rear of the transmission via a separate but attached "transfer assembly" (lubricated with a small quantity of gear lubricant) which turns a propeller shaft.
This prop shaft is connected to the VTM-4, a rear differential with electronically controlled clutches, lubricted by proprietary VTM-4 fluid.
Old 02-05-2009, 12:42 PM   #14 (permalink)
Send a message via AIM to Fir na tine Send a message via Yahoo to Fir na tine
Just to clarify for Spartus and all:
Transmission = ATF-Z1
Front Transfer case = Hypoid 80w90 GL5
Rear Differential = VTM-4
Fir na tine is offline   Reply With Quote
Old 02-06-2009, 06:00 PM   #15 (permalink)
Gear oil 75w90 will work as well.
akulla is offline   Reply With Quote
