ATF Overfill - Honda Pilot - Honda Pilot Forums
Old 11-16-2008, 08:58 PM   #1 (permalink)
Alpo714's Avatar
Send a message via AIM to Alpo714
Default ATF Overfill
Hi guys, I have a 2004 pilot EXL with 4wd.
I recently checked my ATF fluid and noticed that it was a bit low, meaning it was at the lower mark of the yellow dipstick. I went to the auto store and purchased some temporary ATF for my tranny and added one full quart to the car (Yes I should have checked the levels as I added it). But when i rechecked the fluid, i noticed that it was about an inch above the upper mark after my car has been sitting idle for over 2 hours. I plan on dumping out the fluid and refilling it properly in one week, since I do not have the time to do it right away.
Do should I change the fluid right away or can I wait one week to do a full ATF flush?
Regards,
-Albert
2004 Honda Pilot 4WD EX-L w/ Navigation
Alpo714 is offline   Reply With Quote
Old 11-16-2008, 09:00 PM   #2 (permalink)
Alpo714's Avatar
Default Re: ATF Overfill
Originally posted by Alpo714
\ sitting idle for over 2 hours.
-Albert
Sorry guys. What I meant to say is that the car has been sitting with the engine OFF for over 2 hours.
Old 11-16-2008, 11:09 PM   #3 (permalink)
The level should be checked after the vehicles been driven. Check with the engine off. I wouldn't worry about draining a bit out if your going to flush it in a week.
I just changed my ATF the other day. The dealer said 3.3 L should come out, since the torque convertor is still full. I added too much as well, and realized it that checking the the level when idling falsely shows high as well.
Good Luck,
Mike
Pushman is offline   Reply With Quote
Old 11-17-2008, 10:21 PM   #4 (permalink)
ctobio's Avatar
You're not supposed to use non-Honda ATF-Z1 fluid in this car. You can run for a short while with the wrong fluid, but you should change it at your earliest opportunity. Now... the procedure for when the wrong fluid is to change the transmission fluid 3 times (since you can't easily do a full flush).
How bad off are you after adding a whole quart, I don't know. One thing to keep in mind- transmission fluid doesn't evaporate or get otherwise consumed. If you are seriously low on transmission fluid, you have a leak somewhere. You should never have to add a whole quart to a transmission that doesn't leak.
Constantino Tobio
Vehicles in the driveway:
'73 VW Fastback, Marina Blue
'94 John Deere LX176
