Tire Rotation - Honda Pilot - Honda Pilot Forums
Old 10-16-2008, 01:07 PM   #1 (permalink)
Default Tire Rotation
Need some help with this topic!! My wife has an 07 EX-L. i tried to rotate the tire the other day but was not successful. I put my jack at the jack point but then i was not sure where to put the jack stands i did not want to ruin anything. i finally put the jack stand under the rear crossmember, but did not feel comfortable with it there so i just aborted the mission! any help would be great.
2007 Honda Pilot EX-L Nimbus Grey
2008 Toyota FJ Cruiser Slightly Modded
greyYES is offline   Reply With Quote
Old 10-16-2008, 04:15 PM   #2 (permalink)
http://www.piloteers.org/forums/show...216#post317216
Check the link above. That is where you put the the jack stand to jack up the car and use the floor jack to place at four points under the car (Two on the driver's side and two on the pass. side. Check in the owner's manual). Don't ever get under the car with the jack stand only.
Thanks NJGuy
2008 Pilot SE 2WD Silver
OEM Running Board, OEM Cargo Tray, OEM Moon Roof Visor, Full Size Spare Tire, Husky Liner, After market AT cooler
Happydady is offline   Reply With Quote
Old 10-16-2008, 05:44 PM   #3 (permalink)
thanks i knew there had to be some kind of central jack point... just spent (the wife) $30 at the dealer getting the rotation done!! i did not know that it was that much of ripoff until i saw the invoice at home!! i have never paid for that (until now) and wont pay again!
Old 10-16-2008, 11:38 PM   #4 (permalink)
$30 for tire rotation, what a ripoff.
Before I didn't know the jacking points and didn't have jack stand, I used the emergency stand (came with car) and spare time for rotating. Took awhile though.
Old 10-17-2008, 01:54 AM   #5 (permalink)
Hey thanks again. unfortunately it was like 15k miles overdue!!
Old 10-22-2008, 03:49 PM   #6 (permalink)
Tire Plus (http://www.tiresplus.com/) offers free tire roatation with oil change (not any more expensive than other places).
2007 EX-L 4WD
sagaliba is offline   Reply With Quote
Old 10-23-2008, 09:21 AM   #7 (permalink)
NJGuy's Avatar
Seems like a good deal. The only concern I would have would be the techs over-torquing the lug nuts. With the exceptions of Costco and my Honda dealer, every other place I've taken my car where they removed the wheels has over-tightened the lug nuts. Just be sure to check them afterward if you happen to go that route.
'05 Pilot EX-L SBP
Old 02-17-2009, 06:26 PM   #8 (permalink)
Default tire rotation
I recommend to take your vehicle to any reputible car care center or local mechanic that can rotate the tires for you if all you have is the vehicle's jack. If you have the proper jacks, jack stands and torque wrench, then by all means do it yourself. One more thing, no matter who you take the vehicle to for tire rotation, always re-torque the lug nuts as soon as you get home. THis can be done with just the vehicles jack. Good luck.
steelersfan is offline   Reply With Quote
Old 02-19-2009, 06:21 PM   #9 (permalink)
Default Re: tire rotation
Did you mean to say -It can be done with just a vehicle's wrench.
Don't think you need to jack up the car tighten lug nuts.
akulla is offline   Reply With Quote
Old 02-19-2009, 11:26 PM   #10 (permalink)
ctobio's Avatar
Default Re: Re: tire rotation
He means to properly torque them with a torque wrench, which should be done with the wheel unloaded.
Constantino Tobio
Vehicles in the driveway:
'73 VW Fastback, Marina Blue
'94 John Deere LX176
Old 02-20-2009, 08:59 AM   #11 (permalink)
ctobio, thanks for clearing that up for me. You're right, you can use the cars jack to unload the wheel, then loosen all of the lug nuts, on the unloaded wheel, with the vehicles wrench and properly re-tighten with a torque wrench. (Proper torque settings found in the owners manual).
Old 02-20-2009, 12:35 PM   #12 (permalink)
Sorry, no more Tires Plus for me. The local one cross-threaded 3 lug nuts on on 2 different trips for me. Sometimes 'free' just isn't worth it.
2007 Pilot LX
2004 Suzuki V-Strom
Old 02-20-2009, 12:49 PM   #13 (permalink)
Got it.
Old 03-15-2009, 02:29 AM   #14 (permalink)
FWIW, Discount Tire does free rotations.
steelersfan: how do you torque the nuts on an unloaded wheel when it can spin freely?
Some Beach is offline   Reply With Quote
Old 03-15-2009, 09:37 AM   #15 (permalink)
ctobio's Avatar
I can wedge my boot underneath, and you'd be surprised how well that works. Alternatively, a brick will also work.
Constantino Tobio
