![]() ![]() ![]() ![]() Join Date: Mar 2007
I am sure someone has posted this before, but I did a search, and could not find it.
My Pilot has just reached 10,000 miles and needs to replace VTM-4 rear differential fluid. Do I need to take this back to the dealer, or any shop can do it? I think that Pilot uses special differential fluid, don't know if any shop would stock them. |
Any shop should be able to replace the VTM-4 fluid, however, in Midland no one except the Honda dealer stocks the VTM-4 fluid used by Honda. So, I always buy the fluid and take it to my mechanic who does the work.
My B1 service light had come up, so I made an appointment yesterday to have oil change/tire rotation today. But this morning, when the odometer exceeds 10,000 miles, the service minder suddenly changed to B16. I checked the forum, isn't first VTM-4 rear differential fluid change supposed to be around 15,000 miles? Anyway, the place I take my car to is not a Honda dealer, and I don't have time to go to Honda dealer to buy fluid. So I am thinking wait till the next service interval to replace the VTM-4 fluid. Wonder if the "6" minder will come up next time when I need oil change?
2007 EX-L 4WD |
the '6' will probably not appear next time the maintenance minder pops up. after your mechanic resets the mm for the oil change/rotation, the mm will assume you have also changed the VTM4 fluid, so it won't appear until ~30k miles. i know pilots have two service schedules, 'normal' and 'severe'. if your pilot falls under the 'severe' category (driven hard, towing often, going off-road or using 4WD often), then i'd say you should replace the VTM4 now. otherwise, i see no problem in waiting till your next oil change do to the VTM4.
2006 Pilot EX-LN 4WD | Taffeta White | "Amelia" OEM accessories: chrome side steps, crossbars, cargo tray, cargo cover, wheel locks, rear splash guards, door edge guards, full-size spare Aftermarket accessories: Yakima Big Powderhound, LED license plate and door bulbs, Infinity 6012i speakers, 4300k HID, 35% tint, Nokya yellow fogs + yellow Lamin-X |
It's very common for the MM system to call for a VTM change around 10K for the first one, then they go to more like 15K-20K. On mine, it's also calling for ~5K oil changes more or less, which seems awfully often as well. Whether it really needs it or not, no idea, but I'm following the system.
Isn't it an amazing coincidence that the cars which include "free maintenance" during the warranty period (e.g, BMWs and MBs) have very extended maintenance periods, but those in which you have to pay for maintenance (e.g., Honda), seem to require quite frequent maintenance. - Mark |
![]() ![]() ![]() ![]() ![]() Join Date: Nov 2005
2006 Black Pilot EX-L w/ NAVI Chrom Step Bar/Roof Cross Bar/Clarion 10" RES/Soundgate AUX + PIE LD-1 audio booster/ Momo Shift Knob/Interior white bulb/Parrot CK3100 Bluetooth Handsfree/PIAA style White Headlight Bulb/Techone H11 HID kit/Polk db651 speakers/Michelin Cross Terrain 2008 Mazda Ti-Grey RX8 GT 6MT 2007 Blue/Silver Honda CBR600RR 2007 Black Honda CBR 125R (Sold) 2004 PWP TSX (Sold) 2004 Blue Mazda6 (GS-I4 w/ sports package) RIP 1997 Silver CR-V (traded w/ '06 Pilot) |
I just took mine in for VTM-4 fluid change. Dealer charge US$120.
2007 EX-L 4WD |
#9 (permalink) | |
06 Pilot Ex 4WD (RIP Old Friend) 08 Acura MDX New Family Truckster - Wifes 2011 Tacoma 4x4 Double Cab TRD Off-Road - Mine |
About $25/gal. Only comes in gallons. You'll use about 2.75 quarts, so your next change, you're buying another gallon. Same with the next one as well, and then finally, the one after that, you'll have enough from the last gallon you bought to not have to buy another.
Make sure you use the oldest one first. Fluids do have a shelf life (measured in years, but 30k after the first change averages out to every couple of years or so.)
Owner's manual says 15,000 miles. But from reading posts here, looks like the "6" maintenance minder usually comes up synchronized with the oil change between 10,000 miles and 15,000 miles.
Mine came up shortly after 10,000 miles when I was on my way for an oil change (see my previous post).
2007 EX-L 4WD |
#14 (permalink) | |
I plan on doing this in the next couple of weeks. |
#15 (permalink) | |
I am changing my vtm-4 2nd time this weekend before winter comes. It's B16 with 60,000km(37,500miles). This time I got the crashable washer.
