did half a** brake job - Honda Pilot - Honda Pilot Forums
Old 09-05-2008, 02:40 AM   #1 (permalink)
Send a message via AIM to 03pilotONE
Default did half a** brake job
ok I just got done changing brake pads... I attemped to remove the rotors to have them turned... but I could not get the screws off the rotors so I just left them and just replace the pads. is that bad?.. rotors felt smooth, and the pads where not that thin to even cause damage to the rotors.. will I be ok? will i have to replace the pads even sooner because I did not resurfacing the rotors?..
03pilotONE is offline   Reply With Quote
Old 09-05-2008, 06:59 AM   #2 (permalink)
Default Re: did half a** brake job
The "right" way to get the screws off is to use an impact driver (The kind you hit with a hammer) and a #3 Philips tip.
Most people don't have a #3 Philips and try to use a #2 and a regular driver.
once you bugger the heads, then you just have to drill out the screws. It is very easy to do.
Your pads will last just fine.
Old 09-05-2008, 01:11 PM   #3 (permalink)
ctobio's Avatar
Every time I rotate the tires, I exercise those screws so they don't rust in place.
That said, if the rotors are no thinner than the halfway point between new and minimum thickness, and there isn't any evidence of pulsation on brake application, and there's no grooving, then the rotors are fine to reuse as is.
Constantino Tobio
Vehicles in the driveway:
'73 VW Fastback, Marina Blue
'94 John Deere LX176
Old 09-05-2008, 05:18 PM   #4 (permalink)
krygny's Avatar
Every time I ever did disk brakes myself, that's all I bothered to do. I never had a problem and it was a lot cheaper and easier. Unless the rotor is warped or scored by the wear tabs, cutting is usually not necessary. You'd be surprised at how many shops don't turn rotors (even if they say they did). Some will just tell you you need new ones and replace them. They've gotten generally cheaper too.
2003 EX-L, Sage Brush Pearl
Old 09-05-2008, 11:06 PM   #5 (permalink)
Thanks guys i feel alot better now... now all i gotta do is a brake fluid flush...
Old 09-06-2008, 12:13 AM   #6 (permalink)
ctobio's Avatar
I might be doing one as well this weekend. I ought to document the job with the Motive Power Bleeder.
Constantino Tobio
Old 09-07-2008, 04:43 PM   #7 (permalink)
Please let us know how it goes with the Motive bleeder. I could never get the cap on mine to seal on the Pilot. I have used it with great success on our Volvo, but that uses the threaded cap- not the chain/screw deal for the Honda.
geopilot is offline   Reply With Quote
Old 09-08-2008, 10:08 PM   #8 (permalink)
ctobio's Avatar
I bailed on it this weekend because of the absurd humidity we were having because of TS Hanna. Perhaps this weekend.
I think I should be able to do this, though.
Constantino Tobio
Old 09-12-2008, 01:47 PM   #9 (permalink)
I did mess up the front rotor screws.
Somehow the rear ones came out no problem.
How do you guys suggest I take them out?
They seem to be rusted well. Drill with a left hand drill or what else. I did try an extractor and all it did was to break the tip of the extractor bit.
Any clue for the part number of the replacement screws?
Cheers
Nick
nickg5 is offline   Reply With Quote
Old 09-12-2008, 04:17 PM   #10 (permalink)
Did you drill off the head?
Most of the time they come out easy once the tension is gone.
Old 09-12-2008, 10:19 PM   #11 (permalink)
ctobio's Avatar
No, but Honda might be able to help you (Brandfon Honda is closest). If you can't find one, I think the front and rear screws are the same, and if you can get a good one off, you can match it up at your local Fastenal. There's one in North Haven, on Sacketts Point Road off of I-91.
Constantino Tobio
Old 09-13-2008, 09:02 PM   #12 (permalink)
nope. Unfortunately I chewed the phillips head off while I was trying to take them off. I used an electric impact screwdriver (screws would not budge). I am sure they are rusted after a couple winters in New England.
