![]() ![]() ![]() Join Date: Apr 2008
Any of you guys use sea foam before? I'm thinking about using it and wondering what results you guys have come up with by using this.
here's a link for those who don't know what sea foam is... http://www.seafoamsales.com/motorTuneUpTechGas.htm |
#2 (permalink) | |
![]() ![]() ![]() ![]() ![]() Join Date: May 2003
Thanks, Robrecht! Charcoalishlygreenishbluishyrealpink&tealfleck metallic EXL-RES with Rumble Seat, Foglights, Chrome Bumper Garnish (of course!), and Merrywang Transport Netting. And an RX-8 or Miata for my twice daily hill climb. |
Used it on my truck (155k) via gas tank and it smoothed the idle and acceleration,
Then tried it in inlet without anything spectacular happening
If I'm correct, by cleaning the intake manifold you mean adding sea foam to the break booster line right? My friend did it to his prelude a few days ago, adding it to the brea booster line and gas tank. Afterwards he said while he was driving, the car felt like it wasn't even turned on. how do i do a piston soak? |
here's my favorite seafoam
2006 Pilot EX-LN 4WD | Taffeta White | "Amelia" OEM accessories: chrome side steps, crossbars, cargo tray, cargo cover, wheel locks, rear splash guards, door edge guards, full-size spare Aftermarket accessories: Yakima Big Powderhound, LED license plate and door bulbs, Infinity 6012i speakers, 4300k HID, 35% tint, Nokya yellow fogs + yellow Lamin-X |
Amazing stuff. Pour it in the intake. Pour it in the crankcase. Pour it in the gas tank. This stuff does EVERYTHING!!
Worked great for me--I learned that it doesn't cure baldness.
Just think what it will do if put in your tires.
Funny thing though- Seafoam is no snake oil, and I'm a big skeptic.
I have a '97 Honda Passport just sitting in my driveway for no good reason. It sat for 3 months waiting for me to replace a power steering hose. The car ran a bit rough when I finally fired her up. So, I dumped some seafoam in the tank in a fairly high concentration, and deep-creeped the intake, and damned if it doesn't idle a bit smoother now and growl a little less. I have yet to Seafoam my Passat, but I use it in my small engines as well when I give them a little cleaning.
#14 (permalink) | |
If you're going to do a seafoam this way, here's what I recommend: Disconnect the line at the brake booster. Stick a tee in that line. Take a length of hose and stick it one one end of the tee. Take another length of hose and stick it on the other end of the tee. Take a clean, clear plasic bottle and put in 6 oz of seafoam in it. Now, dip one end of the tee hose in the bottle. The other end of the tee that's not in the brake booster line is open to the air. Basically, this allows you to slowly siphon seafoam from the bottle. Try to keep the RPMs at around 2000 when you do this, and shut off the car as soon as you're done siphoning. Wait about 30 minutes, then drive it like yo stole it. It'll look like you're mosquito fogging when you drive. Once the white smoke is done, you're done.
#15 (permalink) | |
the brake booster is the big, black saucer shaped object behind the brake fluid holder against the driver’s side firewall right? ![]() an extra pic for additional clarity...
