Engine Malfunction Light - Honda Pilot - Honda Pilot Forums
Old 08-12-2008, 09:24 AM   #1 (permalink)
Default Engine Malfunction Light
Changed my spark plugs a few weeks ago. The day after the engine malfunction light came on and went off after I restarted engine. On the way to work this morning the light came on again and didn't go off this time. Was wondering if anyone knew what I need to check. The manual says its related to emissions. I've got 127,000 mi. Trying to keep from having a huge repair bill. Any help or suggestions would be greatly appreciated.
etsooner is offline   Reply With Quote
Old 08-12-2008, 01:16 PM   #2 (permalink)
Default Re: Engine Malfunction Light
Get the code read.
Without the code everyone is just guessing.
Some here have amazing confidence in their guesses.
Old 08-12-2008, 10:04 PM   #3 (permalink)
ctobio's Avatar
Your local autozone will scan the codes for free. Post the results here. I suspect a misfire, but that's pure speculation.
Constantino Tobio
Vehicles in the driveway:
'73 VW Fastback, Marina Blue
'94 John Deere LX176
Old 08-12-2008, 10:33 PM   #4 (permalink)
You were correct. Went to autozone and it said that it was a misfire. Not sure if I need to change the wires or just see if i didn't get it put back on good. It said a misfire on number 4. Not sure which one that is.
On the way home from work, was rolling my window down and it stuck. I hear a clicking sound but no window movement. Glad the rain stopped this morning. Isn't my week for the vehicle.
Old 08-12-2008, 11:21 PM   #5 (permalink)
ctobio's Avatar
I would try this:
Swap the coilpack with the cylinder next to it. If the misfire returns on plug number 4, you have an issue with that spark plug- gap is wrong, or the plug may be defective.
If the misfire follows the coilpack, you may have a defective coilpack.
Constantino Tobio
Old 08-13-2008, 02:42 PM   #6 (permalink)
As stated in the previous post, the Autozone readout stated I had a misfire in number 4. Does anyone know the order of the plugs so I don't have to guessing which one it is? Any help would be appreciated.
Old 08-15-2008, 12:38 AM   #7 (permalink)
ctobio's Avatar
For some reason, I had a hard time getting this info. It's not on the valve covers, nor is it anywhere obvious in the Service manual.
Anyway, standing in front of the car:
Rear bank closest to firewall goes, left to right:
1-2-3
Front bank, closest to radiator goes, left to right
4-5-6
So, swap 4 and 5 and see what you get.
Constantino Tobio
